They do wear very quickly and not great in the wet. Good tyre in the dry though.
I think there very good in the rain tbh
Ive been running them for a number of years now and like them. Paid £90 a tyre last time around aswell. Grippy in the dry and wet, they go off quick though when about 1/2 to 3/4 worn
Like a lot of performance Tyres, Yokohama included they use a duel compound to make them cheaper once you get to the harder rubber it's time to change them. I didn't think they were as good as others in the wet, but that's subjective.
I had this problem first on a set of Yokohoma AVS sport. They where so sticky at first and had so much grip but suddenly just went off (Jenson Button style). I looked into it and that's what I was told,
To produce a tyre with a duel compound it costs more to blend the two compounds together.
The AVS sport as it wear's down, like any 'v' tread pattern can overheat in dry conditions due to air flow not passing over the tread blocks hence loss of grip, and not to clever in the wet either as water displacement is hopeless. No idea what they were thinking following all the others with a 'v' tread pattern. .
Why use a duel compound then?
