ross p
Back at last....
Jul 13, 2007
464
Glasgow
www.firstrespondernm.co.uk
Hi all,
Wondering if anyone can have a look at the logs below and let me know what may be wrong wrong with the car and a resolution?
Symptoms are rough idle and without touching the accelerator the revs increase to 1750 the drop to idle again.
Thanks,
Saturday,05,January,2013,18:47:19:16836
VCDS Version: Release 11.11.4
Data version: 20120807
Chassis Type: 1K0
Scan: 01 03 08 09 15 16 17 19 25 42 44 46 52 56 62 72
VIN: TMBEF21Z182006841 Mileage: 115560km/71805miles
01-Engine -- Status: Malfunction 0010
03-ABS Brakes -- Status: Malfunction 0010
04-Steering Angle -- Status: OK 0000
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: OK 0000
15-Airbags -- Status: Malfunction 0010
16-Steering wheel -- Status: Malfunction 0010
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: OK 0000
25-Immobilizer -- Status: OK 0000
42-Door Elect, Driver -- Status: Malfunction 0010
44-Steering Assist -- Status: OK 0000
46-Central Conv. -- Status: OK 0000
52-Door Elect, Pass. -- Status: Malfunction 0010
56-Radio -- Status: Malfunction 0010
62-Door, Rear Left -- Status: OK 0000
72-Door, Rear Right -- Status: OK 0000
Address 01: Engine Labels: 06F-907-115-AXX.lbl
Part No SW: 1Z0 907 115 D HW: 8P0 907 115 B
Component: 2.0l R4/4V TFSI 0010
Revision: 5BH16--- Serial number: SKZ7Z0G4111936
Coding: 0203000318070060
Shop #: WSC 73430 790 00000
VCID: 36651B5F4106B9A8CB9
7 Faults Found:
008825 - Leak in Air Intake System
P2279 - 002 -
Freeze Frame:
Fault Status: 01100010
Fault Priority: 2
Fault Frequency: 3
Mileage: 114991 km
Time Indication: 0
Date: 2000.00.00
Time: 16:50:15
Freeze Frame:
RPM: 798 /min
Load: 14.5 %
Speed: 0.0 km/h
Temperature: 60.0°C
Temperature: 10.0°C
Absolute Pres.: 990.0 mbar
Voltage: 14.224 V
001287 - Idle Control System RPM
P0507 - 001 - Higher than Expected. - Intermittent
Freeze Frame:
Fault Status: 00100001
Fault Priority: 2
Fault Frequency: 17
Mileage: 114991 km
Time Indication: 0
Date: 2000.00.00
Time: 16:50:33
Freeze Frame:
RPM: 1002 /min
Load: 15.3 %
Speed: 0.0 km/h
Temperature: 58.0°C
Temperature: 20.0°C
Absolute Pres.: 970.0 mbar
Voltage: 14.351 V
008583 - Bank 1; System too Lean at Idle
P2187 - 004 - - MIL ON
Freeze Frame:
Fault Status: 11100100
Fault Priority: 2
Fault Frequency: 2
Mileage: 115009 km
Time Indication: 0
Date: 2000.00.00
Time: 17:05:58
Freeze Frame:
RPM: 866 /min
Load: 14.1 %
Speed: 3.0 km/h
Temperature: 87.0°C
Temperature: 28.0°C
Absolute Pres.: 980.0 mbar
Voltage: 14.224 V
001089 - EVAP Emission Control Sys
P0441 - 002 - Incorrect Flow - Intermittent
Freeze Frame:
Fault Status: 00100010
Fault Priority: 2
Fault Frequency: 2
Mileage: 115031 km
Time Indication: 0
Date: 2000.00.00
Time: 23:12:37
Freeze Frame:
RPM: 753 /min
Load: 17.2 %
Speed: 0.0 km/h
Temperature: 87.0°C
Temperature: 21.0°C
Voltage: 14.224 V
000768 - Random/Multiple Cylinder Misfire Detected
P0300 - 002 - - Intermittent
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Mileage: 115297 km
Time Indication: 0
Date: 2000.00.00
Time: 20:36:20
Freeze Frame:
RPM: 1294 /min
Load: 13.3 %
Speed: 0.0 km/h
Temperature: 89.0°C
Temperature: 35.0°C
Voltage: 14.097 V
000770 - Cylinder 2
P0302 - 002 - Misfire Detected - Intermittent
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Mileage: 115297 km
Time Indication: 0
Date: 2000.00.00
Time: 20:36:25
Freeze Frame:
RPM: 789 /min
Load: 15.7 %
Speed: 0.0 km/h
Temperature: 89.0°C
Temperature: 35.0°C
Voltage: 13.843 V
000256 - Mass Air Flow Sensor (G70)
P0100 - 004 - Supply Voltage - Intermittent
Freeze Frame:
Fault Status: 00100100
Fault Priority: 2
Fault Frequency: 1
Mileage: 115533 km
Time Indication: 0
Freeze Frame:
RPM: 0 /min
Load: 0.0 %
Speed: 0.0 km/h
Temperature: 90.0°C
Temperature: 49.0°C
Absolute Pres.: 1030.0 mbar
Voltage: 12.446 V
Readiness: 0000 0000
Address 03: ABS Brakes Labels: 1K0-907-379-MK60-F.lbl
Part No SW: 1K0 907 379 AC HW: 1K0 907 379 AC
Component: ESP FRONT MK60 0101
Revision: 00H11001
Coding: 0004738
VCID: 73E3E24B12F4EC802C7
1 Fault Found:
01314 - Engine Control Module
013 - Check DTC Memory - Intermittent
Address 08: Auto HVAC Labels: 1K0-907-044.lbl
Part No SW: 1Z0 907 044 R HW: 1Z0 907 044 R
Component: ClimatronicPQ35 110 0401
Revision: 00110021 Serial number: 00000000000000
Shop #: WSC 00000 000 00000
VCID: 45876C930CE02230523
No fault code found.
Address 09: Cent. Elect. Labels: 3C0-937-049-30-H.lbl
Part No SW: 3C0 937 049 AJ HW: 3C0 937 049 AJ
Component: Bordnetz-SG H54 2202
Revision: 00H54000 Serial number: 00000004889088
Coding: 018C0F030004140000110D000000000000087F075C000000000000000000
VCID: 71EFE84368E8DE90DEB
Subsystem 1 - Part No: 1Z2 955 119 C Labels: 1KX-955-119.CLB
Component: Wischer 270407 022 0601
Coding: 00055223
Shop #: WSC 73430
Address 15: Airbags Labels: 1K0-909-605.lbl
Part No SW: 1K0 909 605 T HW: 1K0 909 605 T
Component: Q4 AIRBAG VW8 020 2300
Revision: 05020000 Serial number: 0038PD17M6ZY
Coding: 0020788
VCID: 3D77047364306AF00A3
1 Fault Found:
00532 - Supply Voltage B+
002 - Lower Limit Exceeded - Intermittent
Address 16: Steering wheel Labels: 1K0-953-549-MY8.lbl
Part No SW: 1K0 953 549 BC HW: 1K0 953 549 BC
Component: Lenksäulenmodul 036 0070
Coding: 0000012
VCID: 74E1E15717FAEBB835D
1 Fault Found:
00888 - Wiper Switch for Intermittent Operation (E22)
014 - Defective - Intermittent
Address 17: Instruments Labels: 1K0-920-xxx-17.lbl
Part No SW: 1Z0 920 942 C HW: 1Z0 920 942 C
Component: KOMBIINSTRUMENT VD1 1612
Revision: V1612036 Serial number: SKZ7Z0G4111936
Coding: 0003401
Shop #: WSC 25069 576 88123
VCID: 387915674B124FD8D95
Address 19: CAN Gateway Labels: 1K0-907-530-V3.clb
Part No SW: 1K0 907 530 L HW: 1K0 907 951
Component: J533 Gateway H07 0052
Revision: H07 01 Serial number: 130507F2000373
Coding: E9807F060002021303
VCID: 30692D47A3629798915
Address 25: Immobilizer Labels: 1K0-920-xxx-25.clb
Component: IMMO VD1 1612
Shop #: WSC 20036 576 88123
Address 42: Door Elect, Driver Labels: 1K0-959-701-MIN3.lbl
Part No SW: 1T0 959 701 D HW: 1T0 959 701 D
Component: Tuer-SG 005 0954
Coding: 0000756
2 Faults Found:
00943 - Heated Exterior Mirror; Driver Side (Z4)
012 - Electrical Fault in Circuit
00109 - Left Mirror Turn Signal Lamp (L131)
Address 44: Steering Assist Labels: 1Kx-909-14x-44.clb
Part No: 1K2 909 144 L
Component: EPS_ZFLS Kl.074 H07 1806
VCID: 35671C535C00B2B0C23
Address 46: Central Conv. Labels: 1K0-959-433-MAX.clb
Part No SW: 1K0 959 433 BT HW: 1K0 959 433 BT
Component: KSG PQ35 G2 020 0204
Revision: 00020000 Serial number: 00000000000000
Coding: 81801A085283007F3F04050FC0085F96907C00
VCID: 8303328BC2545C00BC7
Subsystem 5 - Part No: 1Z0 951 171
Component: Innenraumueberw.008 4801
Coding: 00000000
Shop #: WSC 73430
Part No: 1K0 951 605 D
Component: LIN BACKUP HORN H07 9001
Component: NGS n.mounted
Address 52: Door Elect, Pass. Labels: 1K0-959-702-MIN3.lbl
Part No SW: 1T0 959 702 D HW: 1T0 959 702 D
Coding: 0000756
VCID: 397F1063701856D026B
1 Fault Found:
00944 - Heated Exterior Mirror; Passenger Side (Z5)
Address 56: Radio Labels: 1K0-035-1xx-56.lbl
Part No SW: 1Z0 035 161 C HW: 1Z0 035 161 C
Component: Radio FO3 019 0040
Revision: 00019000 Serial number: SKZ7Z3G0009903
Coding: 0000402
Shop #: WSC 07013 074 60311
VCID: 2E55333FB9568168839
1 Fault Found:
00872 - Bass Speaker Rear Left (R15)
011 - Open Circuit
Address 62: Door, Rear Left Labels: 1K0-959-703-GEN3.lbl
Part No SW: 1K0 959 703 J HW: 1K0 959 703 J
Component: Tuer-SG 006 1201
Coding: 0000144
Shop #: WSC 73430 790 1012544
VCID: 377B165B460C40A0D0F
Address 72: Door, Rear Right Labels: 1K0-959-704-GEN3.lbl
Part No SW: 1K0 959 704 J HW: 1K0 959 704 J
Coding: 0000144
End ---------------------------------------------------------------------
