Finchy not sure if you fixed yours yet.
Basically big end of rubber over the nuespeed pipe. Jubilee it on. The small end over the turbo and jubilee that on also.
As for the heat shield I got an adjustable spanner put it around the teeth of the cover mounting points and cracked them anti clockwise. No need to catch tje nuts on the under side. Once cracked the undo by hand. Out heay shield in place and redo then back up.
