Finchy not sure if you fixed yours yet.
Basically big end of rubber over the nuespeed pipe. Jubilee it on. The small end over the turbo and jubilee that on also.
As for the heat shield I got an adjustable spanner put it around the teeth of the cover mounting points and cracked them anti clockwise. No need to catch tje nuts on the under side. Once cracked the undo by hand. Out heay shield in place and redo then back up.
Ive gta wait till monday now. Stripped all pipe and because i had to tighten 1 of jubilee clips that tight ive bent it lol. Ive managed to put my heat shield on tho looks gud.
Has any one got any tips on fitting cheers??
What ever u do lift the engine cover from the right side of he cover the bit that has the air feed connected to the air box and slam panel as the hpfp in under there and they break very easily apart from that watch ur next 3 tanks of fuel disappear as u keep playing with the throttle to listen to darthvader under ur bonnet
I still need someone else to drive mine to see how it sounds outside the car. If it's that loud inside it must be loud outside?!
They are not that loud outside of the car , makes a nice subtle noise
always louder in the cabin though.
The best noise i get is lifting off in 6th around the legal limit , makes a lovely chatter :)
I've heard quite the opposite. My wife said she could hear me coming around the corner.
But strangely nobody ever turned their head, so that makes you think it doesn't make any noise out.
A mate of mine also heard me coming once.
But god it's a lovely noise :) I miss it so much.
Too bad it sounds like ass on a diesel :( I was about to put the order in for one until I saw a clip of the p-flo on a CR170.
