how many mtrs 19mm hose for pcv delete?
adambudders
292
on the edge of reason
will i get away with just one meter of 19mm silicon hose for deleting the pcv system?
i'll be mounting the catch tank in place of the fuse holder on the bulk head.
cheers,
adam.
RICKY3
1,002
AYRSHIRE
Thats where i wanted to mount mine an 1m is on the tight side i would get 1,5m as i had to order more hose
Sent from my iPhone
FroggyLCR
Yellow Beastie
Oct 2, 2012
251
Norwich
Hi guys, if you don't mind, where are you running your hose from the engine to the catch can from on the engine, and then where are you feeding the return hose back to.
Any chance of a photo or two?
Many thanks as really wanna do this!
Nov 4, 2012
510
Callington Cornwall
Sorry to jump in i have had this done on mine it goes into the hockey putt without a catch can. I need to get a new 90 bit that comes out of the sump anyone know of a uprated part for that???
RICKY3
1,002
AYRSHIRE
Forge have new block and rocker ends out
I got new (pattern) plastic one ebay £14
Ebay 200767943806
Reactions: matty85
RICKY3
1,002
AYRSHIRE
Forge ones
Sent from my iPhone
FroggyLCR
Yellow Beastie
Oct 2, 2012
251
Norwich
Has anyone done this on a AMK engine with the non return valve in the brake servo line as in the guide in the link above? Or can you do the catch tank with out this and not blank off the other brake servo line?
As its a brake line I don't want to do owt wrong!!
Many thanks!
