Petes Mk3 Cupra Hybrid Ko4, Round 2.
Big-Pete
Always on the Limit
Aug 8, 2010
3,032
ok
so i had a mk3, in red, and it was beautiful until some scrote did 3ks worth of damage to it, so devastated i got rid, bought a 306gti-6 blew it up after a month and have now procured a mk3 cupra in red, with a bit of work done.
some pics before i got it.
cheeky vid of it at MRC [B)]
Spec is as follows.....
2001 Ibiza Cupra.
• 1850CC WOSSNER PISTON KIT
• FORGED H-BEAM CON RODS
• N/A +1mm CAM SHAFTS
• TURBO DYNAMICS STAGE 4 HYBRID K04 TURBO
• XS POWER TUBULAR MANIFOLD
• Q-PENG 2.5” DOWNPIPE
• SCORPION CAT-BACK EXHAUST
• MRC TUNING CUSTOM REMAP
• JETEX AIR FILTER
• FORGE DV
• FMIC
• AUDI S3 MAF
• SEAT SPORT STRUT BRACE
• RACE TECH BOOST GAUGE
• POWERFLEX WISHBONE BUSHES
• OMP LOWER STRUT BRACE
• CUSTOM FABRICATED REAR STRUT BRACE
• BBS CV 7.5X17”
• COILOVERS
• FERODO DS2500 FRONT PADS
• BRAIDED BRAKE LINES F+R
• SPEC STAGE 4+ CLUTCH KIT
• 5.5KG G60 SINGLE MASS FLYWHEEL
AUDI S2 SPARK PLUGS
B7 RS4 IGNITION COILS
SOLID FRONT ENGINE MOUNT
These are the new parts fitted over the two years, these are nearly all GENUINE parts, all servicing is done by myself and oil changes happen every 3000 miles without fail.
Door handle trims
Numberplates
Spark plugs (Audi S2)
Leon Cupra R Fuel pump
N75
N/S/R Wheel bearing
Tubular manifold
Hybrid K04
Various gaskets/Nuts/Bolts
Silicone hoses
Tyres
Clutch release bearing
Head gasket
Gear shift cable
Seat Sport strut brace
ARB droplinks
Air flow meter (audi S3)
N/S Mirror glass
Rear Pads
Battery
Stem seals
Set of valves
Downpipe
Citroen Picasso aerial
Injectors
N/S/F window lifter
Handbrake cables
Front DS2500 Pads
Breather hose
More various seals and gaskets
Lambda sensor
Brake discs
Audi RS4 Coils
LCR spoiler
Timing belt / Water pump
Head bolts
Oil jet
Impulse rotor
main bearing bolts
Big ends
Mains
Thrust washer
Pistons
Rods
Oil pump tensioner
Inlet man. Injector inserts
Rear crank oil seal
AGN Cams
N/S/R Caliper
:-o
and a standard pic of when i first got the car.
yea all the colours are off its taken on a potato the cams ****,
im gonna get it all spiffy clean and tidy tomorrow and ill take some more piccys for ya :)
Big-Pete
Always on the Limit
Aug 8, 2010
3,032
haha lol,
yeah lads plans are a plenty,
full detailed, will need another clay bar soon as its ****in minging by the arches
Big-Pete
Always on the Limit
Aug 8, 2010
3,032
Update got a black rear view coming and an aftermarket omp boss :) which is for a polo but I'm guessing it will fit as it did with my 16v Ibiza.
