Lew89
309
Oxford
Hi Guys,
Considering getting a FMIC for my pd130 I'm remapped to about 170bhp. Am I going to notice any performance benefits from fitting a FMIC (other than lower intake temps) or would I need another remap to notice the difference.
Running stock internals just a de-cat miltek and panel filter.
I will most likely be going for a THS as the welds are much stronger i understand. I think my SMIC got knackered when my turbo went pop 30k miles ago.
anyone got any rolling roads before and after a fmic on a PD130 whilst running a stage 1 map? I really wanna know what (if any) bhp/mpg ill be noticing?
I do know dark side developments offer a smic rated upto 230bhp for around 275 if that's any use to you
Proberly loose power with the side mount from heat soak. So a fmic will benefit alot. Best mod I've done
What sort of gains will I get approx on a stage 1 revo map with fmic? Will the mpg be a good gain also?
I haven't mapped mine but I'm going stage 2 when I'm ready. I assume you'll be in the 170 bhp bracket on a revo map
What can the s s intercoolers handle? When I got one off eBay it turned out the cores where burst, so whoever had it must of ran high pressure. Ended up with the ths one, much better built
