Ok this may be weird but just drove it again to the petrol station & the noise started again.. The fuel is below a quartre so maybe this noise is coming from the fuel side of things? Gonna put some redex in it and see if it makes a difference with a full tank
I was going to say it sounds like the turbo is experiencing surge but without hearing it in the flesh it's hard to say.
Your code can be seen here.
http://wiki.ross-tech.com/wiki/index.php/16825/P0441/001089
Looks like you've got your work cut out for you.
16825 is to do with the carbon canister. If u have removed this then you will get this code when the car sits an idles.
Sean's Xperia arc
Yes, I listened to the video. It could be related to faulty solenoids/valves controlling flow to the carbon canister. I have a Haynes manual for the Ibiza 93-99, I'll have a look tomorrow and see if it covers yours or gives an idea to were it may be.
I've been getting to grips with a brother sewing machine for most of the evening, made in 1960 something. Sew, going to bed now.![]()
but does SAI stand for "standard air intake. "?
