razorfish086
Hi All,
I'm new to this forum. I was wondering if it is possible to retrofit OEM Valeo Bi-Xenon Headlights to a 2012 Exeo SE Tech 2.0 TDI?
I know this will be expensive and am wondering what I need to purchase?
Purchase: The two headlights (Codes: 3R2941753 & 3R2941754). I gather the bulbs come with the headlights.
Other Parts??
Any suggestions greatly appreciated. Has anyone else done this?
I'd like this as well, but the main problem would be fitting the headlight washers (these are an MOT requirement for Xenons)
I opted for Xenon look bulbs instead, they don't have the LED DRL's but they do look nice and blue/white and cost about £10 :)
It's a lot of work, if there xenon your gonna need headlamp levellers unless you have a sport and also going to have washers to pass the mot. As far as I know xenon lights use a ballast like hid system so your gonna need that too. I would imaging the wiring is different but that's easy to overcome using a part of the headlight harness and a lot of solder assuming its not the same.
