Oem ones to be honest. Direct from vw trade specialist..
Sent from my GT-I9300 using Tapatalk 4
Do you reckon there would be any takers for the standard suspension on fleabay ?
Remapped?
Sent from my Galaxy Nexus using Tapatalk 4
Yep, recently Stage 2. Didn't think it would go straight away but the clutch has been on the car for a while with Stage 1 so bound to go in the end.
Think I'll just bite the bullet and go with the Helix SMF kit!
Top work mate! Took me ages to do my switches , dash etc in it!
Ak
Fitted new coils as mine were the original ones and I'm coming up to 70k..
Here you go.
Doesn't show that well in pics and I expect it will settle a bit as well.
Before..................................................After
Did you replace the topmount bush as well?
Thinking I may go for the 50/40 kit now. I'd want the front to sit a bit lower
I think I have a coolant leak, hoe much do you think I'd be looking at spending to fix it, change cam belt, water pump and full service. Iv been given a rough quote at around £300, is that good value?
That seems a bit to cheap for that lot,
where is the leak coming from?
I wouldn't put rad weld in mate! Anything that could block up waterways on an engine like that can't be good!
Ak
