leon cupra - winter protection
jake
I AV MOSTLY BEEN BEATING
Feb 2, 2003
2,666
rochdale
Visit site
I used a guide off here, but the struts have been superseded or something,
There both rated 600nm were the oem ones are 380nm so it's stupid stiff, the guide part numbers are wrong, so for anyone doing it don't get the fabia struts, tomorrow I'm going sourcing correct struts that are about 450-500 and the correct length, then ill give the info
The bumpers are about £6 and the struts £15 ish. That's all then it's a case of vagcom coding,
Jake
jake
Feb 2, 2003
2,666
rochdale
Visit site
Here's the shite that was made by a so called reputable exhaust company.
See what I mean!!!!!!!!!!!
Jun 27, 2012
1,049
Belfast
Cars looking really well. Loving the facelift boot lid + lights, looks fantastic.
Do you plan on fitting the white Orion's soon?
jake
Feb 2, 2003
2,666
rochdale
Visit site
Lol yeah I know.
I want to fit a boost gauge but im not paying £40 for a tiny bit if metal. Where can I tee in for boost feed.
jake
Feb 2, 2003
2,666
rochdale
Visit site
Tyres are sailun they get ok right ups and I've seen decent videos on them. Tbh any winter oriented tyre will knock spots of a summer tyre.
I also put nd Goodrich winters on the Mrs car and on the drive back you could feel the better grip, seven doing a test emergency stop from 40mph in the wet the abs dint even have to kick in.
[M]ike
269
Under the sea
how to make your own 90mm custom intake
before I even got the k1 I had been looking at the tuning aspect, and realising these cars are bloody expensive, im not the type to pay £400 for an intake, no matter how nice it looks,
so heres your shopping list:
1x70>90mm silicone hose
2x90mm 90degree silicone hoses
1xmetre 90mm alloy pipe
5x80>100 jubilee clips
1x60>80 jubilee clips
Metal rod
Air filter of choice
Tools:
Air saw
Dremel/air grinder
Sanding wheel
Heres how to do it:
The scary bit is cutting your engine cover, once you have this in hand you’ll see how and were to cut, you basically need the maf pipe, don’t forget take the maf sensor out before doing any cutting as they are fragile!!!! You have been warned
You want to get the oval maf pipe to the stage were the coupler fits on,
Next you need a piece of alloy pipe 10.5” long, fit this into the coupler and then onto one of the elbows,
The next pipe is 6.5” long and has the other elbow and filter on it (I chose a ramair filter which can flow over 400bhp)
I then made a couple of brackets out of the steel bar, to hold everything in place, and cut my engine cover to suit,
Heres how it all looks now
DSC_3199 by cuprajake1, on Flickr
DSC_3191 by cuprajake1, on Flickr
IMAG0154 by cuprajake1, on Flickr
DSC_3189 by cuprajake1, on Flickr
Jake
Nice work you did there. Are you still happy with the reasaults of the mod? Think i might give this a go. Can you give me a heads up where you orderd the parts Jake? Cheers!
