What size core is that mate I want one just like that. Cheers, Josh.
Sent from my iPhone
Is it core size or bore size? Tail pipe is 6" x 4" Oval, Bore size is 2.5".
Sent from my iPhone
heres a few pics as promised, and i parked up next to an FR+ so naturally had to snap a couple haha, shame really cos it used to be a lot lower. Engine raisers are on the way though so shall be back kissing the tarmamc
will probably redo the stripe, was a bit off a rush job and i did it on the car so not the best lol
Will the ap coil overs from a Cupra r fit a 180 Cupra?
Yep, just the bracket on the coilies for the front ARB becomes redundent as your ARB bolts to the lower wishbone
Ravi, I'm not personally a fan of the wrapping you've done to your car, that's just my opinion. However, for some reason I love that tip on your spoiler! Wheels look quality too, keep this Motorsport theme going mate!
if done properly a roof should take about an hour (should really remove aerial for the best finish) and the spoiler about another hour (needs to come off too) mirrors are difficult if you are doing it the first time but you can do themagain about an hour a mirror to do it properly. badges can be done pretty easy if youve got a slatted grill i suppose you could but its more effort than its really worth, i just rattle canned my grills
New clutch + new dmf = scarily low new biting point and 100 yards of kangarooing down the road in between stalling the sod! New battery in too and some new wiper blades tomorrow, also nearly finished making my air vent gauge pod.
IIRC the biting point doesn't change as it's hydraulic.Mine was the same just even lighter
