Step 1 - Getting an XP Install Ready
Goto
https://www.virtualbox.org/wiki/Downloads and download and install VirtualBox.
Windows hosts = For people running Windows XP / Windows Vista / Windows 7 / Windows 8 on their laptop
OS X hosts = For people with a MacBook
Once VirtualBox is installed download the Extension Pack from the same link as above. Double click the downloaded file which should open in VirtualBox and install the Extension Pack.
Now we need to download a legitimate Windows XP installation to run in VirtualBox.
Goto
http://www.modern.ie/en-us/virtualization-tools click ‘Get Free VM’s’ In the ‘Select Desired Testing OS’ drop down click:
Windows = if you’re using a Windows laptop
Mac = if you’re using a MacBook
In the ‘Select Virtualization Platform’ drop down click:
VirtualBox on Windows = If you’re using a Windows laptop
VirtualBox for Mac = If you’re using a MacBook
Now you’ll be presented with a bunch of choices. Download the IE6 - XP files, part1 and part2. They are self-extracting rar archives. Once extracted you should be able to import the appliance (the extracted file) into VirtualBox. (Sorry I can’t be more detailed here I don’t use Windows as my main OS).
Once imported we need to change the configuration of the virtual machine, to disable internet connectivity mainly. This will have two affects. 1) the VCDS software won’t be able to update or call home, 2) anything happening inside the virtual machine, i.e. those worried about installing viruses etc, won’t be able to get out onto your
network.
Edit the virtual machine settings under the
Network section and uncheck the ‘Enable
Network Adapter’ option.
So in this first step we've gotten ourselves a dedicated install for VCDS that runs virtually, has not
network connectivity and cannot impact your laptops on Windows/OS X install in any way.
