give me a reason why I would want to reply to this..
I'll catgorise it as my opinion.... but keep it to myself ;)
Thought i had explained it in an earlier post but here goes again
I remember on some earlier Revo tunes they were requesting more fuel pressure than a standard pump could produce
as you have a upgrade you may be able to reach the values that are being requested
Its from memory so like i said im not sure if its 100% right so that's why I asked the question
Everyone was on 104 octane fuel?or 98?
cheungys lowewer boost run was his higher octane map I think. 104 I presume if thats what apr offer
I dont think any other car than cheungys has wmi on it tho.. Not that I saw (aside from my own)
Correct. We created a special file for him that runs high boost on 98, but he wanted to see how the standard 104RON map faired against his high boost file. Over the past few weeks we've bounced logs back and forth WMI performance with the 104 map to ensure he's not damaging his engine, and he and I both wanted to see how it faired.
Screw all these logs and r/r plots. Which one is fastest?
logs are there to disect
Cheungy said:
mark cousins 341.5 333 APR 2+ (v3.4 Latest Map from APR)
david cheung 345.9 338 APR 2+ (104ron (old)Map using 50% Meth)
david cheung 344.4 359.3 APR 2+ map2 ("Test" HiBoost Map also with Meth)
For the record I don't drive a Cupra and the 3.4 is not available (still in the development stages) or something along those lines...I could be wrong but whatever
It pulled more timing on the 104 map than it did on the big boost map
Its map sensor under reads by some 400mb too
:handbags:
Bill - how quick does your car go out of interest? In terms of lap times, 1/4 mile times, terminal speeds, 30-130 etc.
Don't you agree that it would be worthwhile to get some of these things documented also to back up these plots?
You know yourself that different people driving there cars at different places etc arent exactly comparable. You Leon is almost a second slower on the 1/4 these days, then when you put your times in.
My Mk1 with 250bhp was competitive with the stage 2+ MK2s last year etc
Track times are a bit the same - if I'm a second quicker than you on track, is it because I have 30bhp more, or because i pushed harder?
That's my point sir. All this data, all the plots and all the BS don't make a car fast. The combined package of car and driver does.
The 30-130 thing to me sounds like the thing that would show performance without much driver skill needed other than to keep the steering wheel in the middle and catch gear changes quickly at the right revs.
Having said that, when you are separating 5/10 or even 20bhp, there isn't going to be a whole lot in it. Weight, aerodynamics, rolling mass and other things will play as much in to that as power differences too.
Interesting though it is seeing different codes, plots, logs etc compared for me at least, its all a lot of :w4nk:
