googujube
LCR225
Jan 1, 2013
366
York
Any help appreciated,
It's an LCR
3" dp with 100 cel sports cat mated to standard
Wellycooler
s2000 open cone
Samco TIP
007p Forge
Should it be boosting THAT high and do things look generally healthy?
BETTER/MORE LOGS ADDED IN POST 7
The car will be going for a remap (stage 2) in the next couple of weeks.
115 would also show requested boost. actual is @ mapped levels not std.. which wopuld be 1800-1900mb
Cheers.
When I first got the car I was told it was mapped. I had it dyno'd to see what kind of power it was producing.
This is a printout from around a year ago.
The dyno shows standard (ish) power. Not being an expert on printouts I read the bhp figures and just assumed it was standard and thought no more of it.
About 8 months later when I decided to uprate the rods the mechanic found the C1 middle piston ring "in about 20 pieces".
Wondering now if this map potentially have caused the ring failure?
yes mapped and has initial typical from most mappers (not me) overshoot to 2550mb
fueling has been adjusted where some miss that
timing CF is ok..
its got the usual torque intervention on that plot tho (wobbly power/torque lines)
timing CF is ok..
Thanks a lot Bill I really appreciate that.
