Watched that earlier, has some skills does Mr Block
Have you seen the one he did in San Fransisco?
Cool. Where you from? I'm in St Andrews.
Sent from my SM-N9005 using Tapatalk
He's not that good, as his rallying record proves. Bit of a different story when you have unlimited tyres and can go back and run the scene again until you get it right.
Sent from LG G2 using Tuppytalk
Cleaned my egr and manifold today. Wasn't as bad I thought it would be but needed doing anyway.
Before
After
Is it normal for the hose leading to the egr to look this bad?
is yours a pd170 mate? want to do the same with mine but can't seem to find a guide to doing it on my engine.
What oil is everyone using for there leon TFSI Fr??
Pd140, not sure if they are the same, but it was just a matter of undoing a few Allen keys and making sure you don't drop anything in the engine bay. Its very messy but worth it.
This may help you, although most isn't relevant as its for the delete not clean, so its not necessary to remove all the pipework as shown, just the egr itself.
http://www.tdisport.com/Forum/viewtopic.php?t=9505
Im planning on doing my Pd170 Egr valve on friday to..I did my Audi A4 one and it was a messy job..I never noticed a difference after I'd done it...mines got stuttering issues I've done the map re-tweak twice and the reduction gasket and its still there in 3rd so gunna try the Egr now.
