Motul RBF 600 brake fluid
big eck
3,976
Falkirk, Scotland
Where's the cheapest place to buy this from??? Seen it for £27.99 delivered on the net but the site looks kinda dodgy.
I think I need 1ltr of it to completely flush out the old stuff yea???
Was gonna go for the ATE super blue but this gets very good reviews so gonna try it.
865
'up anley duck'
ive got the super blue in mine and its makes a massive difference. the brakes are super sharpe.
i got mine from demon tweeks
Dopedpanda
"Old" Hardcore Ford Fan
Jun 15, 2013
172
Denmark
Better than oem fluid?
There is no such thing as better fluid for transfering force to brakes.
People that have gotten "better" brakes after a fluid change, would also have gotten the same resultat using tap water.
All fluids are 99,99999% non compresseable, nothing in this world are know to change a fluids state on this. And that is all brake fluid does, transfer force through its non compresseable form.
You can talk about compressible flow, but thats not something you gonna discuss unless you work at NASA or something.
EDIT: the reason people (typical track car) changes to something higher spec (and thats all it is, no magic in between the different manufacturs there) is the boiling point (both wet and dry)
Different colours of brake fluid can help you bleed the car better to see you got all the old stuff out.
betty_swollox
Richie
Feb 15, 2011
5,497
7
Washington
Lol I ride bikes and bleed my own brakes so I don't need a lecture thanks :p
Obviously brakes with any change of brake fluid will feel great compared to old brake fluid, I was hoping the lad who commented had compared them back to back with fresh oem fluid and uprated fluid...
ibizacupra
Jack-RIP my little Friend
Jul 25, 2001
31,333
19
glos.uk
the spec explains the difference....
dry boil point..
like for like new thats your comparison for choice, along with ££ you wish to spend
george g
74
dry boil point..
And for that exact reason I chose the normal DOT 5.1 for road/spirited driving...
shnazzle
Glass-Half-Full Member
Sep 9, 2011
3,480
Northumberland
possibly massive difference between (used) OEM fluid and AEM or RBF...
If the OEM one has taken in water (which it will have over time), it will feel spongy as **** compared to some nice fresh AEM or RBF.
Higher boiling point also means you can brake harder for longer without feeling fade...which is a right pain in the hoop
To answer the OP's orginal questions:
I got my RBF600 from Opie Oils: I got mine on an easter deal and it was £10.xx/500ml - It's Currently £12'ish but you can enter a SCN code and get 10% discount IIRC.
I checked a guide on VW Vortex and it mentioned needing ~1.15ltr of fluid if you want to bleed the clutch slave cylinder as well.
[edit]
The reason most folk see such a dramatic difference after changing any brake fluid is because the old stuff is probably full of water, boiled etc... etc... anything will be better than old fluid, but of course it's best to put in decent stuff!
[/edit]
big eck
3,976
Falkirk, Scotland
I had the fluid changed over for pagid dot 4 stuff only a few months ago but the brakes went very spongy after a few laps at knockhill. If I can get some nice stuff that works just as well day to day but at the same time perform brilliantly on the track without a spongy pedal after a few laps then I'll be more than happy.
