Fixed up the boost gauge as it wasn't reading properly anymore. Removed the pill, as I've got a stepper motor gauge anyway and re-secured the boost tap adapter. That did the trick!
25 idle vacuum and 16psi boost peak with instant response on throttle.
Booked my car into AMD Essex for a cam follower bucket change & stage 1 map on 22nd august
Change the cam follower yourself mate it's a piece of piss to do!
And also, drop the car off and leave it there and come back and get it as AMD are notoriously slow!
Took them 7 hours to remap mine!
well, I was bored and couldn't think of any new mods to do to the car so seeing as these are the current trend amongst wheel *****s and VDUB folk I purchased a set and fitted them tonite...
I don't mind them and they break the hole black thing up a little...
Had ABS, ESP and TPMS lights greet me today..... after switching the engine off and back on it left only the ABS light on, which itself dissapeared a moment later. Torque Pro found no codes so I'm guessing that I'm ok to not worry too much..... that warranty is really going to be stretched otherwise!
Cheers. Spent last night digging through logo .png files on google :)
Didnt want to get too elaborate in case it didnt work!
James down there seemed like a nice guy. Really easy to deal with over the phone. I can see why they are rated.
nice work m8
id love a different start up screen on mine,was it easy to do?
Cheers, yes its dead easy.
Using either Photoshop or even MS Paint, just create an 800x400px canvas, and then make your design, save as a .jpg and pop it on a usb stick.
Then you put the headunit into setup mode, import your design off the stick, save it, then reset the unit.
Biggidy-bang, new splash screen.
Can give you step by steps if required.
nice 1 m8,pm me some details please;)
