Because I've got v3.4 but my BAP BAP BAP didn't work when I tried it, and I haven't fiddled with switching maps.. Infact I don't know if I'm even selected in Stage 2+ mode.. I'm assuming I am? Unless they've put stage 1,2 and 2+ on there??
Mmmm a 'bap off'sounds like my kinda partaay
Sounds like you should go test it out like i did!
I have absolutely no recall of changing the mode it was set on when I drove away from Richard Martins after it was mapped. And i know for a fact it was defo on S1, however i had never tried to hit the limiter.
Was only this weekend when it was pretty wet so couldnt get power down, which is probably why i didnt think it might not have been running the right map!
I just worked my way through the maps, and by the results i would say:
Mode 1 - S1 remap with added baps
Mode 2 - valet, i couldnt do over 4k and about 50mph
Mode 3 - stock premium fuel
Mode 4 - stock poverty fuel
Possibly the otherway for 3 and 4 but could easily tell they werent S1 or valet with my quick tests.
Only concern was an ESP warning which seemed to crop up after turning off the engine and turning on ignition again to change mode. If i turned it off a second time, everything was fine. Weird, maybe i was putting the ingnition on too quick after turning engine off and some sensor gets its pants in a bunch or something.
well my dealer set mine up as follows ;-
1) stock
2) 95 octane
3) 98-99 octane
4) Valet mode
I have the v3.4 apr stage 1 and I didn't even know about the baps until on here and other members mentioning it, and I found out last week ..and it scared me a bit when I heard it ..did it in 2nd gear
I never touch the settings as I'm sure to **** up so mines on 98/99 fuel setting .
1) stock
2) 95 octane
3) 98-99 octane
4) Valet mode
How do you change it? I'm gonna have a go at lunch time
This is how mine was set up.
They took me for a quick spin to show the difference between mode 3 & 4.
Haven't hit the rev limiter yet. Not really much chance up and down the A1 with the roadworks and average speed cameras they have now set up.
And still achieving the same mpg is a bonus.
Damnit Locky, you had one job!
Apparently mine has a password, and I've tried inputting it but I get nothing happen.. Annoying
just spoke to wayne at awesome gti about the v3.4 map regarding the motorsport limiter
basically all ecu's arent compatible and like mine might need a 'custom' file or a reflash to enable it?
he's gonna speak with apr and send my details off-ecu number and vin to see if it can be done
not sure on cost wise also he said?maybe labour costs for putting on im not sure
Its gotta be something like 1234 or 0000 surely if they didnt tell you it. Be a bit harsh to let you ride off not knowing how to change your map. What happens if you can only get 95ron fuel or something and need to disable your S1 map?
I think Josh mentioned further back that some pre-FL ECUs don't support it. Hopefully there is a workaround / file / reflash for you that doesnt cost loads.
Put banana up for sale and ordered a 3 door DSG Golf R mk7 in tornado red with all the trimmings![]()
