abs123
The 'Deposit Part Number' on the invoice is 1P0035501A which is described as a 'BASE'.
did you use your old antenna?
Guest, 🎅🎄Looking for a stocking filler idea? Why not treat yourself or a loved one to our high quality CUPRA or SEAT valve caps. Order now from the merchandise store
Yep - it was actually loose already (thought this originally was the problem) so easy to remove. Some say you can't because of some anti-theft feature so I'd check yours first.
Thanks mac music for the info. Is the 12v adaptor something that has to bought in and if so where do you connect it. I understand that after market units dont send 12 volts to the aerial, do you know if this is correct. Therefore, would a separate 12v supply to the base unit on the aerial do the trick? cheers aggie
