No dont think its illegal as long as not same colour as emergency vehicles.
coil packs starting to failBeen struggling with lumpy idle and misfires, EML light on. Yesterday the EML went out car was running great and this morning my mpg was loads better. Weird
Hope not they've I've only just replaced them all and new plugs. Reckon it's just the dreaded scuttle leaking. Seriously gonna have to figure a way to stop it. Bar silicone I'm not sure what else to do.
Even without trying to seal around the panel, if you plug the 3 holes in the bonnet strip recess, not much water will leak into the engine. And any water which does collect under the bonnet strip in the recess generally will flow out of the back corners when you lift the bonnet a tiny little bit above the horizontal. (If you lift it right up it will pour all over the engine and battery).
So even if no attempt or some attempt is made to try and stop the water getting in there in the first place doesn't work (which it wont) then at least you can minimise how much water gets onto and into the coils by plugging the drain holes and carefully draining it before driving off.
They look good Rob! Would love a set.
Drop me a PM then and we can talk business!I've just received payment for another set (preface lift) so will be making these in the next week or two.
