Just finished my Meth install... All I can say is wow!!!! Enjoyed my test drive home![]()
What set up are you running mate?
Photo session with the car today
No mate loads of room
Retrimmed the door panels today in leather to match
Looks good Matt.
Nice I like it. Is that wrapped on painted. Not see a matt one yet. Subtle mods but look great. Is that the standard fr front bumper with the number plate and backing plate removed?Photo session with the car today
Sounds good dude, have you got any pics of your install as will be doing same on mine very soon. What did you set your start spray and fully open dials at on the controller?
Devils own base kit (6-30 psi switch). Just upped the activation pressure of the switch as it was too much at lower rpm, was holding back/felt flooded.
Amazed me the difference it makes, had IAT within 2 degrees of ambient at WOT at the redline in 4th after boosting through every gear, up to 8 below ambient on the overrun, and the 6 degrees CF I set up on the REVO software is reduced to pretty much no correction at all.
And that's running the TPS screeneash which is 50% Methanol![]()
206 Gti, more of a project for sprints and track days hopefully.
Nice work. Looks so different but so subtleThanks! Car has been plasti dipped, not wrapped.
Yes, that is the OEM front Cupra bumper. I've cut off the fog lights and the backing plate, new ABS mesh as well. AC core has been removed and crash bar modified to allow maximum air flow to the IC.
