What did you and your MK2 do today?
Daniel M
Blackbelts & Chickenheads
Apr 18, 2013
2,873
7
Middlesbrough
Photo session with the car today
That looks great! Always tempted to get some new rear lights. Yours look great.
No mate loads of room :)
Retrimmed the door panels today in leather to match
Looks good Matt.
Dan FR
Meth addict. Stage 2+ Yo!
Nov 14, 2013
1,794
8
Caerdydd
What set up are you running mate?
Devils own base kit (6-30 psi switch). Just upped the activation pressure of the switch as it was too much at lower rpm, was holding back/felt flooded.
Amazed me the difference it makes, had IAT within 2 degrees of ambient at WOT at the redline in 4th after boosting through every gear, up to 8 below ambient on the overrun, and the 6 degrees CF I set up on the REVO software is reduced to pretty much no correction at all.
And that's running the TPS screeneash which is 50% Methanol :D
AlexK1
545
Poole
Sounds good dude, have you got any pics of your install as will be doing same on mine very soon. What did you set your start spray and fully open dials at on the controller?
Daniel M
Apr 18, 2013
2,873
7
Middlesbrough
Took it for a drive to Sams (Jarre) in the snow along with my brothers MK1 so my bro could have his scanned on VCDS.
STU3Y
1,271
Kent
Nice I like it. Is that wrapped on painted. Not see a matt one yet. Subtle mods but look great. Is that the standard fr front bumper with the number plate and backing plate removed?
Dan FR
Nov 14, 2013
1,794
8
Caerdydd
No pics im afraid, very little to see now that the car is back together, just the AKS throttle spacer, nozzle holder and a few inches of pipe :D
Take a look at SamBryants's build, he has pics of his WMI install, mine is pretty much the same.
No controler, just a simple boost activated on/off switch: http://www.methanol-injection.co.uk/index.php?route=product/product&path=27&product_id=36
No need for anything more complicated, and no need to run any wiring in to the car, at all :D
-pseudonymous-
681
Makes a world of difference doesn't it mate, even more so in the summer! What size nozzles are you running?
Dan FR
Nov 14, 2013
1,794
8
Caerdydd
Just a D03 after the TB on mine, being a baby K03 and all ;) Can't remember the CC but the Devils Own site will tell you.
POPOV
Newbie
Jun 25, 2005
581
Sweden
Thanks! Car has been plasti dipped, not wrapped.
Yes, that is the OEM front Cupra bumper. I've cut off the fog lights and the backing plate, new ABS mesh as well. AC core has been removed and crash bar modified to allow maximum air flow to the IC.
STU3Y
1,271
Kent
Nice work. Looks so different but so subtle
AlexK1
545
Poole
Fitted the lower engine mount small bush in the arm with a powerflex bush. Also changed the gearbox oil to redline mtl 75w 80 grade. Fitted blackvue dr530 dash cameras which I'm very pleased with!
