Have to bear in mind if the OP is having to ask about doing the job it'd be surprising if he could curl it out in 15/20mins his first time.
Rears are a doddle. 17mm socket and breaker bar for the wheel and an 18mm socket, spanner and ratchet for try spring cup.
Fronts: 13mm for the top mount, 21mm for the strut top, 16mm for the ball joint, 24mm 12sided socket for the hub nut, 21mm for the brake carriers, 16,17 or 18mm spanner and a spline/torx for the drop links, 17/18 for the track rod, screwdriver, spring clamps or compressor tower.
There abouts anyway.
http://forums.vwvortex.com/showthread.php?3043490-Springs-installation-DIY-for-06-07-Rabbit-!!!
Here you go i followed this
Normal thread mate. I snapped teo breaker bars last week trying to get one out ffs
