Thanks, will have another look tomorrow. spent 30 minutes today (Sunday) and didn't spot that option.I think you can change that in the setup on the radio screen to switch between stored stations rather than scan.
Ours must have been set up like that at the factory, as it scans presets - when you are on the radio screen. Whatever happened to 'proper' buttons . . ....Just did a small vid of it working in my car (assuming its what you want) but im at work so cant upload it now... so in text terms, you want to go into Radio... Setup...Seek Mode - Preset List.
Then the buttons on the left of your steering wheel will now go between the favorite stations and not scan.
I agree with Chris, most of your points seem to be very trivial, I don't think the Seat is any worse than any of the 3 previous new Audi's I've owned in the past.
The A3 stop start could be temperamental as well but no more often than your car.[*]It's almost impossible to make a smooth gear change into 1st
I bought my Seat Leon SC SE (1.4) on finance in September and I'm almost 6 months through the 3 year agreement.
It's my first brand new car, and if I am honest I am not that impressed.
- Water runs in the boot when it's been raining and I open the boot
- Water drips in the car if you open the window when it's been raining
- It takes forever to clear ice from the front window
- The material used around the central screen and the window open/close buttons make it look like someone has eaten a McDonalds then pressed all the buttons.
Anyone else feel like this?
that's awesome mate, just changed it no problem. i hadn't even considered that the Seek Mode would apply to the steering wheelJust did a small vid of it working in my car (assuming its what you want) but im at work so cant upload it now... so in text terms, you want to go into Radio... Setup...Seek Mode - Preset List.
thanks for your time and effort Grease marks on buttons, I treated all my dashboard plastics with 303 Aerospace Protectant, 18 quid for 16floz trigger spray Amazon. Leaves a matt finish that resists UV fade, cracking, dust and fingerprints. I do it once per year on all our cars. I then have a 2 quid microfiber handled duster to swiff around each time I give him a bath.
[*]Water runs in the boot when it's been raining and I open the boot
With Radio/Media selected in your central display between the speedo and rev counter, use the scroll wheel on the RHS of the steering wheel to rotate through the options stored then press the scroll wheel in to change to that selection.
With your radio on and visible in the cars main display you can use the next and previous rocker switch on the left hand side of the steering wheel to skip through your stored stations in the same way that would change tracks on a CD or on MP3's stored on the SDHC card slot.
To demist windows, select both the heating element buttons and have them illuminated. However in the Air con settings accessible via your VDU, you will find an option for having an auxiliary heating element come on in the A/C system during demist or Hi position heat requests, and his need to be enabled.
I found that doing this demisted my car in just a minute or so, much better than all me previous company cars.
I can't find a menu for climate set up on mine!
Is it accessed from the Setup button thats on the middle dial on the heating controls?
and there it was all the time
many thanks!
I have the top 2, not the last option. Maybe the Cupra generates so much heat it doesn't need an additional option hehe
