fitted the RNS 510 MFD3. well on friday before i come away. will be changing the boot logo to a SEAT one from VW on wedensday when get time
![Cool [B)] [B)]](/forums/styles/seatcupra/oldforumsmileys/shades.gif)
Many thanks, a well worth upgrade
It's all if and at mfsw etc all works and so on. Sources it on eBay with brand new antenna etc £400
My face lift OEM MP3 player in piano black with the surround is for sale' need to post in the for sale section
Cheers fella top man![]()
You could get a. Kenwood unit like locky's for that money.
I had the rns510 in my Passat cc and didn't think much of it,![]()
Yeah have to admit Dan I do like the one Paul has in his. Also love what he has done with the start up screen.
Suppose it's just like having a set of 3sdm wheels or alike on your leon' just not for me
its fine if we where all the same it would be so boringNo offence intended just thought the one I had was dim witted/slow to react . Sat nav was poop but then it was in a 7yr old motor.
I think I have maybe a 310 or 315 in my R and the nav alone is so ......less frustrating to use
I'm off to google 3sdm wheels as I haven't a clue
I think it was the larger screen of the kenwood that caught my eye. Is it not oem+ as I'm sure it was an optional extra![]()
Think the kenwood has now been discontinued![]()
You can still get a kenwood dnx-520VBT off eBay, just keep a look out mate. Probably a better solution than a RNS-510 if you don't have factory bluetooth already in your car, with the highline display as the kenwood is an all in one solution.
If you have a PFL car, if you go down the rns-510 route, then PFL cars suffer from a battery drain issue and you'll have to do a little modding to one of the pins in the connector block to cure this issue, there's a good thread on fitting the rns-510 in the faq's which covers it.
Will keep an eye out mate, don't mind a second hand one at the right price so long as it's got everything that comes with a new one and is in good order.
Yeah mine has the built in Bluetooth,phone control on steering wheel and the big MFD.
I'm guessing those would still work with the kenwood![]()
