So my Cupra has been here today
Pete has fitted my new OEM DMF,new bolts,Release bearing + Helix uprated organic clutch plate and cover.
Can't thank him enough for what has been an excellent
service. This was my first experience with him working on my Cupra and would highly recommend him. Without question I'd have more work if needed done there.
Obviously I've not given her any beans yet, but first impressions on the new set up are excellent and very happy with it in every aspect.
Clutch pedal is as expected in the sense of it's harder than stock but not as bad as I'd anticipated.Also the bite point is now different again not in a bad way. Overall it just feels solid and after driving only twenty miles I'm getting to grips with it already.
Whilst she was there he changed my engine oil to the milers 5W/40 that Niki advised me to get along with new oil filter.Also the gearbox oil was changed to the milers 75W/80 as recommended by AKS Alex and Opie Tim.
She feels silky smooth on gear changes and the engine sounds less tapity on tick over compared to when it had the castrol edge 5W/30.
Now down to what the parts were like that got replaced,DMF was on it's way out with a fair bit of movement.Clutch plate wasn't bad in terms of wearing down and would no doubt of got a bit more life out of it.
What caused it to slip was the release bearing that was goosed and covering the clutch plate in oil. But even without that issue it wouldn't have been long before the DMF needed to be replaced.
Either way I'm glad I've changed to the Helix as it gives me the excuse to go stage2
In the meantime I'm going to get booked in at R-Tech for a map tweak since now I've got the BCS fitted it's interesting to see what Niki can do for me.
Then later on in the year will purchase a Loba pump as my first stage2 supporting mod.
Thanks for everyone that has helped me I really appreciate it
Cheers for reading and all comments welcomed
Craig
