www.badger5.biz
stock many of the upgrade/rebuild parts
Cheers Bill, I have purchased from you before.
It turns out the turbo shell looks shot too. May as well go hybrid turbo yes?
Current relevant mods: induction kit and cone 80mm
Mods fitted during repair: manifold (relentless pro4), 3"dp with 200cell cat, cat back, V2.2 B5 TIP, BAM engine with eagle rods.
Any recommendations on turbo, clutch, single mass flywheel, recirc valve and fuel pressure regulator? Might as well do this properly. Diff probably a good idea too? Catchcan required? and then a remap, not sure what ball park to aim for though.
I'm currently looking at:
Turbo:
Irritatingly out of stock atm though.
Clutch: Been recommended helix. Not sure tbh.
Looked at this in the past though:
Flywheel: Not a clue
Recirculation valve: forge
Fuel pressure regulator:
LSDiff: No idea
Any suggestions appreciated.
Cheers, Ash
www.badger5.biz
Mods fitted during repair: manifold (relentless pro4), 3"dp with 200cell cat, cat back, V2.2 B5 TIP, BAM engine with eagle rods, Baffled sump (forge)
Turbo:
Link
Recirculation valve: forge 008 I think, although I have heard the 007 is the preferred route for some reason. Not sure how true this is "I have been advised that the 007p is the better bet as any air being leaked does not pass through the MAF and therefore affects the MAF reading and fueling." Maybe if it is closed off and leaking? Wrong spring?
LSDiff: No idea
Cheers, Ash
hybrid will want 550cc not 4bar fpr
3" downpipe and exhaust, 80mm TIP/Induction, FMIC, water meth, high flow exhaust manifold
Usual hybrid mods... which on a rodded motor should get you in the 330-350bhp range
Thank you Bill.
Any advice on meths? Necessary?
Where can I find 550cc fpr?
