What did you and your MK2 do today?
Clazzer
429
Stoke on Trent
New red top coil pack, plugs and red harness fitted. Surprisingly, the old coil packs were in mint condition!
Jun 25, 2012
920
Gateshead
i had a little dapple with this quick n easy mod today.
Not sure if the missus will appreciate the extra oomph needed to close the hatch
richicupra
1,823
9
Removed front window tints as they were looking a bit tired and scratched. Fortunately they came off pretty easily with a heat gun on low setting, apart from a few small bits of glue which were easy enough to remove with some IPA.
Feb 10, 2012
617
Newquay
There bonded on so wasn't worth the hassle taking them off. I have still got the arm rest, some genuine (porsche) led number plate lights with resistors that are plug and play, k&n air filter plus box for 1.4 tsi oh and some bbs ch reps to sell
alex.o.d
10
Any pictures of wheels
Sent from my GT-N7100 using Tapatalk
Rich - FR
284
Stockton On Tees
A busy couple of days working on mine after a pretty long spell of not being able to work on it. Full service and gearbox oil change using genuine parts.
New rear upper arms, inner spring carrier bushes replaced with Powerflex black edition bushes and new adjuster bolts and washers (3 seized solid) New rear roll bar drop links and full set of Bilstein B4 shocks fitted.
Last was taking it for the four wheel alignment.
Have to say it drives really well, the Eibach and B4 work very well together!
Starting to srtip everything needed off -
Powerflex bushes fitted -
Bilstein B4 and Eibach fitted -
Four wheel alignment -
Martynm14
201
Got a bit bored today, decided to fix the terrible boot light!
Just got back from Modified Midlands event in Leicester as well, was a great, well organised event! Loads of people, loads of cars! Saw a couple of K1's aswell
paPPn7F2j
p3pMlKXrj
p8hZlg8Kj
wclark1238
33
Wigan
Replaced the n/s/r door lock module that did not allow the door to be opened from the outside. Got second-hand part (1P0839015) @ £50 from local breakers. Took about 45 minutes in total to fit. Jobs a good 'un :clap:
G4reth
FR PD170
Dec 4, 2011
393
Middlesbrough
Good stuff Rich, I was thinking of getting some Bilstein's to go with my H&R's.
