Today I shaked the power steering pressure lines and the steering became lighter. Did anyone had problems with those?
That to me suggests that there is still air mixed in with the fluid. Have you tried jacking up the front of the car and with the engine running, turn the steering full lock to full opposite lock 10 times or more to try to let the system purge itself of trapped air? After that check the fluid level again as if you have removed air, the fluid level will have dropped.
Hello,
Has anyone tested what voltage does your alternator generate?
Mine is 14,2 on cold start and around 13,5 after a while.
Is that normal?
Thank you!
Can uneaven tire wear cause problems? My tires are less weared in the center. Because I had the car without the proper tire pressure for a while.
PS: I'm using the correct tire pressure now.
Running with low tyre pressures will have caused the inside and outside of the tyres wear more than the centre part, it would also make the steering heavier than normal!
Yes, the bonnet release is just a Bowden cable - or wire if you like.
If your car has central locking, after you remove the battery you will need to lock all the doors individually, to do this on all the doors except the driver's door, open the doors and on each one find a black soft plastic seal/bung with the shape of an arrow on it near when the door lock is, remove these bungs and place the car in the slot and turn it slightly, refit the rubber bungs and close the doors - they should be now be locked, lock the driver's door using the key. The doors you locked using the mechanical tag can be opened using the inside handles or the central locking when the battery is fitted back into the car.
I think that you should quickly contact the seller with pictures of that damage, it would be handy to have pictures of the packaging as well for proof of damage in transit - if only for them to claim back off their insurance if they had any.
Now, if you were lucky, they might not want you to return it to them, so it be handy to sell on to someone while telling them about that damage, as they might just use it for spares.
I'd guess, only a guess, that the pump will have been damaged as I'd think that there is not too much free space at that point in the housing.
