Ibiza died - just cut out
Big Col
626
89
North Ayrshire
Hello,
Was happily trundling along at 60mph and the engine just suddenly died. All the dash lights came on and I coasted to the side of the road.
All the electrical systems work and the engine will turn over but it wont start.
I'm going to get it VCDS scanned tomorrow - is there anything else I can check or will the scan reveal all?
My hunch is one of the fuel pumps. The high pressure one is expensive isn't it?
Timing belt. I could prise enough of the top cover off to see a belt still there so that 'looks' ok.
Some electrical immobiliser issue? Some electrical sensor issue? Can one duff sensor eg crank cause this?
2010 2l diesel FR. 65K miles. Been faultless for the last 2 years and 35K miles. Fuel and air filters changed 10K miles ago.
Col
Big Col
626
89
North Ayrshire
so gave it a vcds scan and there's no communication to the engine control module
scan this morning,
Code:
Tuesday,02,February,2016,09:43:54:21489
Chassis Type: 6J (6N0)
Scan: 01 03 08 09 15 17 19 25 44 4B 56
VIN: VSSZZZ6J   Mileage: 106650km-66269miles
01-Engine -- Status: Malfunction 1110
03-ABS Brakes -- Status: Malfunction 0010
04-Steering Angle -- Status: OK 0000
08-Auto HVAC -- Status: Malfunction 0010
09-Cent. Elect. -- Status: OK 0000
15-Airbags -- Status: OK 0000
17-Instruments -- Status: Malfunction 0010
19-CAN Gateway -- Status: Malfunction 0010
25-Immobilizer -- Status: OK 0000
44-Steering Assist -- Status: Malfunction 0010
4B-Multifunc. Module -- Status: OK 0000
56-Radio -- Status: OK 0000
Address 01: Engine
Cannot be reached
Good scan from a while back
Code:
Friday,03,July,2015,19:19:29:21489
VIN: VSSZZZ6J   Mileage: 90320km-56122miles
01-Engine -- Status: OK 0000
03-ABS Brakes -- Status: OK 0000
08-Auto HVAC -- Status: OK 0000
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: OK 0000
44-Steering Assist -- Status: OK 0000
Address 01: Engine (J623-CFHD)       Labels: 03L-906-018-CFF.clb
   Part No SW: 03L 906 018 CR    HW: 03L 906 018 A
   Component: R4 2,0L EDC   H20 6750
   Revision: 43H20---    Serial number:
   Coding: 00190012042500080000
   Shop #: WSC 99999 1023 2097151
   ASAM Dataset: EV_ECM20TDI01103L906018CR 003003
   ROD: EV_ECM20TDI01103L906018A.rod
   VCID: 7CF7BBA4F7B896C1327-8029
No fault code found.
Readiness: 0 0 0 0 1
Any thoughts? dead ecu? Electrical connectivity issues to the ECU? Does the engine ECU have its own fuse?
dm222
1,488
49
At first I would check all fuses. Also check the fuses above battery for continuity.
Put a complete scan.
Big Col
626
89
North Ayrshire
hi
complete scan
Code:
VCDS Version: Release 14.10.2 (x64)
Data version: 20150311
www.Ross-Tech.com
Address 01: Engine
Cannot be reached
Address 03: ABS Brakes (J104)       Labels: 6R0-907-37x-ESP82.clb
   Part No SW: 6R0 907 379 AJ    HW: 6R0 907 379 AF
   Component: ESP8.2i front H05 0001
   Revision: --------
   Coding: 130248DB836F00BAC82D12E7C1D200821700
   Shop #: WSC 04941 000 00000
   VCID: 0603D94CB574DC11543-8053
2 Faults Found:
02214 - Tire Pressure Warning
            002 - Lower Limit Exceeded - Intermittent
             Freeze Frame:
                    Fault Status: 00100010
                    Fault Priority: 0
                    Fault Frequency: 2
                    Reset counter: 114
                    Mileage: 106443 km
                    Time Indication: 0
                    Date: 2016.01.29
                    Time: 06:39:19
             Freeze Frame:
                    Hex Value: 0x0000
                    Hex Value: 0x8000
                    Hex Value: 0x1203
                    Hex Value: 0x2BB6
                    Hex Value: 0x5B7F
                    Hex Value: 0x7F81
                    Hex Value: 0x7F00
01314 - Engine Control Module
            004 - No Signal/Communication
             Freeze Frame:
                    Fault Status: 01100100
                    Fault Priority: 0
                    Fault Frequency: 40
                    Reset counter: 79
                    Mileage: 106651 km
                    Time Indication: 0
                    Date: 2016.02.01
                    Time: 07:17:14
             Freeze Frame:
                    Hex Value: 0x0007
                    Hex Value: 0x0002
                    Hex Value: 0x10FD
                    Hex Value: 0x259A
                    Hex Value: 0x007E
                    Hex Value: 0x7F80
                    Hex Value: 0x7BF9
Address 08: Auto HVAC (J255)       Labels: 6R0-907-044.clb
   Part No SW: 6J0 820 043 B    HW: 6J0 820 043 B
   Component: Climatronic   H07 0505
   Revision: S0000000
   VCID: 2345A0D82286093953D-8076
4 Faults Found:
00457 - Control Module for Network (J519)
            013 - Check DTC Memory - Intermittent
             Freeze Frame:
                    Fault Status: 00101101
                    Fault Priority: 6
                    Fault Frequency: 1
                    Reset counter: 117
                    Mileage: 98259 km
                    Time Indication: 0
                    Date: 2015.10.07
                    Time: 16:13:56
01317 - Control Module in Instrument Cluster (J285)
             Freeze Frame:
                    Fault Priority: 6
                    Fault Frequency: 1
                    Reset counter: 114
                    Mileage: 99655 km
                    Time Indication: 0
                    Date: 2015.10.27
                    Time: 17:40:36
01316 - ABS Control Module
             Freeze Frame:
                    Fault Priority: 6
                    Fault Frequency: 1
                    Reset counter: 114
                    Mileage: 106175 km
                    Time Indication: 0
                    Date: 2016.01.25
                    Time: 17:05:43
            004 - No Signal/Communication - Intermittent
             Freeze Frame:
                    Fault Status: 00100100
                    Fault Priority: 6
                    Fault Frequency: 1
                    Reset counter: 119
                    Mileage: 106651 km
                    Time Indication: 0
                    Date: 2016.02.01
                    Time: 07:12:25
Address 09: Cent. Elect. (J519)       Labels: 6R0-937-08x-09.clb
   Part No SW: 6R0 937 087 F    HW: 6R0 937 087
   Component: BCM PQ25 H+4  H46 0221
   Revision: BF046001    Serial number: 0345 182101719
   Coding: 3C8829E888612500922000003E0B1CC80080400F608C0000200000000000
   Shop #: WSC 64564 324 38760
   VCID: 408F0F54D3D032212EF-8015
   Subsystem 1 - Part No SW: 6R0 959 802 N    HW: 6R0 959 802 N  Labels: 6R0-959-802.CLB
   Component: J386__TSG_FT  003 3130
   Coding: 030000
   Subsystem 2 - Part No SW: 6R0 959 801 Q    HW: 6R0 959 801 Q  Labels: 6R0-959-801.CLB
   Component: J387__TSG_BT  003 3130
   Coding: 020000
   Subsystem 3 - Part No: 1K8 951 171 A
   Component: DWA-Sensor 00  001 0103
   Coding: 000000
   Subsystem 4 - Part No: 1K8 951 605 A
   Component: LIN BACKUP HO  H11 9004
   Coding: 000000
   Subsystem 5 - Part No: 1K8 951 171 A
   Coding: 000000
Address 15: Airbags (J234)       Labels: 5K0-959-655.clb
   Part No SW: 6R0 959 655 M    HW: 6R0 959 655 M
   Component: VW10AirbagA03 H08 0020
   Revision: --------    Serial number: 003GZ0002L90
   Coding: 003033
   Shop #: WSC 06401 785 00200
   ASAM Dataset: EV_AirbaVW10BPAVW250 A01001
   ROD: EV_AirbaVW10BPAVW250_SE25.rod
   VCID: 4C972B64E798E641C27-8019
   Crash sensor for side airbag; driver side:
   Serial number: 3495RRB40676Q5E6FO2T
   Crash sensor for side airbag; front passenger side:
   Serial number: 3505RRB40696Q5E6D8QT
Address 17: Instruments (J285)       Labels: 5K0-920-xxx-17.clb
   Part No SW: 6J0 920 902 C    HW: 6J0 920 902 C
   Component: KOMBI         H05 0404
   Serial number: 00000000000000
   Coding: 410800
   Shop #: WSC 99999 123 12345
   ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A04086
   ROD: EV_Kombi_UDS_VDD_RM09_SE25.rod
   VCID: 2959B2F048AAD369191-807C
1 Fault Found:
12648448 - Function Restricted due to Missing Message(s)
          U1111 00 [009] - -
          Confirmed - Tested Since Memory Clear
             Freeze Frame:
                    Fault Status: 00000001
                    Fault Priority: 6
                    Fault Frequency: 13
                    Reset counter: 79
                    Mileage: 106650 km
                    Date: 2016.02.01
                    Time: 06:56:18
Address 19: CAN Gateway (J533)       Labels: 6N0-909-901-6R.clb
   Part No SW: 6N0 909 901     HW: 6R0 937 087
   Component: GW-K-CAN TP20 0221
   Coding: 422100
   VCID: 70EF9F94A3F0E2A19EF-8025
1 Fault Found:
             Freeze Frame:
                    Fault Priority: 2
                    Fault Frequency: 14
                    Reset counter: 79
                    Mileage: 106650 km
                    Time Indication: 0
                    Date: 2016.02.01
                    Time: 06:56:19
Address 25: Immobilizer (J334)       Labels: 5K0-920-xxx-25.clb
   Part No SW: 5K0 953 234     HW: 5K0 953 234
   Component: IMMO          H05 0404
   Serial number:
   Coding: 000000
   Shop #: WSC 00000 000 00000
   ASAM Dataset: EV_Immo_UDS_VDD_RM09 A03008
   ROD: EV_Immo_UDS_VDD_RM09_SE25.rod
   VCID: 6ADB8DFC8D2C1871D0B-803F
Address 44: Steering Assist        Labels: 6Q0-423-156.clb
   Part No: 6R0 423 156 B
   Component: LenkhilfeTRW        V277
   Coding: 11221
   Shop #: WSC 06402
   VCID: 2F6D5CE8EA4EBD59C75-807A
1 Fault Found:
            49-00 - No Communications
Address 4B: Multifunc. Module        Labels: None
   Part No: 6J0 959 441
   Component: MF-Modul       0007 0001
   Coding: 0000001
   Shop #: WSC 77005 000 00000
   VCID: 70EF9F9463F0E2A19EF-8025
Address 56: Radio (J503)       Labels: 6J0-035-153.clb
   Part No SW: 6J2 035 153 E    HW: 6J2 035 153 E
   Component: Radio         H10 0107
   Revision: R0000000    Serial number: SEZAZ2K1067060
   Coding: 0501040002
   VCID: 285FB7F45BA0EA6106F-807D
End-------------------------(Elapsed Time: 02:36)--------------------------
The tyre pressure warning was me forgetting you need to press and hold it. I was repeatedly pressing it for a second. Still asleep, d'oh. It got new tyres fitted the night before. I assume thats what triggered it.
dm222
1,488
49
Looks to me like the engine control module has some problem. Check fuses under the steering wheel and inside the box on the right (picture).
Big Col
626
89
North Ayrshire
Making some progress now...
Fuse 32 has blown. Marked as 'engine control unit' in the book. Borrowed the fuse for the 12V socket, turned the key and.... it's alive!
Decided to call it a day there. Ran out of time and daylight. I'll give it another VCDS scan in the morning.
Obviously concerned what caused the fuse to blow and after replacement will it just blow soon after again? Need to go and buy some fuses.
Thanks, dm222 for sharing your wisdom
dm222
1,488
49
Among other reasons it could be a bad ground connection, a overload caused by the ECU, a short circuit (a wire damaged that is touching the chassis) a bad connection, etc.
If you did anything in your car recently I would check that first.
I would check voltage at ECU, measure block 053 under the engine (module 01) and compare with other units, for example power steering module 44 (measure block 001 and 004).
And other times they just blow for no reason, but if it blows more than once then you have a problem for sure.
Big Col
626
89
North Ayrshire
I've not touched anything or had any work done except new tyres.
So plan tomorrow. VCDS scan - should get a full scan - save a copy and then clear all codes. Go for a drive. Buy fuses. Leave the fuse box cover off incase I need quick access again.
You think the engine control module might show something before the fuse blow?
dm222
1,488
49
As I said above if there is no errors the only thing you can check with vcds that I know of is the voltage. engine module -> measure block 053
When the voltage is low the current increases to compensate causing the fuse to blow.
Also check if the battery clamps are tight (check if they don't move). If they move could be there the problem, but be careful not to overtighten, only 6 or 7nm tight wich is pretty low using a wrench.
Big Col
626
89
North Ayrshire
I checked the battery yesterday and everything appeared clamped down and solid. However I was unable to get full access to the battery due to the battery cover. I'm doing this in the work car park with limited tools.
So first VCDS scan after fuse 32 was replaced yesterday PM.
Code:
www.Ross-Tech.com
Wednesday,03,February,2016,09:44:39:21489
01-Engine -- Status: Malfunction 1010
09-Cent. Elect. -- Status: Malfunction 0010
1 Fault Found:
4629 - ECM Power Relay Load Circuit
          P068A 00 [032] - Opens Too Early
          Intermittent - Not Confirmed - Tested Since Memory Clear
             Freeze Frame:
                    Fault Priority: 2
                    Fault Frequency: 1
                    Mileage: 0 km
                    Date: 2000.00.00
                    Time: 00:00:00
Readiness: 0 0 0 0 0
   Revision: --------
2 Faults Found:
             Freeze Frame:
                    Fault Priority: 0
                    Fault Frequency: 2
                    Reset counter: 114
                    Mileage: 106443 km
                    Time Indication: 0
                    Date: 2016.01.29
                    Time: 06:39:19
             Freeze Frame:
                    Hex Value: 0x0000
                    Hex Value: 0x8000
                    Hex Value: 0x1203
                    Hex Value: 0x2BB6
                    Hex Value: 0x5B7F
                    Hex Value: 0x7F81
                    Hex Value: 0x7F00
             Freeze Frame:
                    Fault Priority: 0
                    Fault Frequency: 3
                    Reset counter: 119
                    Mileage: 0 km
                    Time Indication: 0
                    Date: 2016.02.02
                    Time: 16:26:08
             Freeze Frame:
                    Hex Value: 0x0007
                    Hex Value: 0x0002
                    Hex Value: 0x10FD
                    Hex Value: 0x2598
                    Hex Value: 0x007F
                    Hex Value: 0x7F7F
                    Hex Value: 0x7D00
   Revision: S0000000
4 Faults Found:
             Freeze Frame:
                    Fault Priority: 6
                    Fault Frequency: 1
                    Reset counter: 117
                    Mileage: 98259 km
                    Time Indication: 0
                    Date: 2015.10.07
                    Time: 16:13:56
             Freeze Frame:
                    Fault Priority: 6
                    Fault Frequency: 1
                    Reset counter: 114
                    Mileage: 99655 km
                    Time Indication: 0
                    Date: 2015.10.27
                    Time: 17:40:36
             Freeze Frame:
                    Fault Priority: 6
                    Fault Frequency: 1
                    Reset counter: 114
                    Mileage: 106175 km
                    Time Indication: 0
                    Date: 2016.01.25
                    Time: 17:05:43
             Freeze Frame:
                    Fault Priority: 6
                    Fault Frequency: 2
                    Reset counter: 119
                    Mileage: 106651 km
                    Time Indication: 0
                    Date: 2016.02.01
                    Time: 07:12:25
   Coding: 030000
   Coding: 020000
   Coding: 000000
   Coding: 000000
   Coding: 000000
2 Faults Found:
00532 - Supply Voltage B+
            011 - Open Circuit - Intermittent
             Freeze Frame:
                    Fault Status: 00101011
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 119
                    Time Indication: 0
00538 - Reference Voltage
             Freeze Frame:
                    Fault Priority: 3
                    Fault Frequency: 1
                    Reset counter: 119
                    Time Indication: 0
   Coding: 003033
   Coding: 410800
   Coding: 422100
1 Fault Found:
             Freeze Frame:
                    Fault Priority: 2
                    Fault Frequency: 15
                    Reset counter: 119
                    Mileage: 106650 km
                    Time Indication: 0
                    Date: 2016.02.01
                    Time: 06:56:19
   Serial number:
   Coding: 000000
   Coding: 11221
   Shop #: WSC 06402
1 Fault Found:
            49-10 - No Communications - Intermittent
   Coding: 0000001
   Coding: 0501040002
End-------------------------(Elapsed Time: 02:16)--------------------------
I've cleared all the codes and I'll go for a drive at lunchtime.
The measuring blocks thing to check the ECU voltage I need to do this with the engine running?
Big Col
626
89
North Ayrshire
so - cleared the codes this morning and I've just been for a short run (round the car park) and a longer 2-3 mile run. Car ran fine, no dash lights and a VCDS scan after both runs still shows no errors.
I couldn't do the measure block thing with the engine module, that tab is not available.
I did measure the PAS module which was showing a voltage hovering between 13.8 and 14V.
dm222
1,488
49
That voltages are normal, but the goal was to compare the two to see if it's losing voltage at the ECU.
Big Col
626
89
North Ayrshire
yup, I understand that but the 'meas. blocks' button on the 01- engine control module under Basic Functions was greyed out. It wasn't available.
dm222
1,488
49
That's strange, mine isn't. Maybe it's your engine that doesn't permit that.
By the way the other voltage was fluctuating between 13,8V and 14V without moving the car? it should be constant, it changes over time between 14,4V and 13,8V but only after a while.
Over all I guess you will have to wait to see what happens, I really don't know what more can you check, that voltage is irrelevant without comparing to the ECU.
I don't know if it is frequent for the Ibiza to break fuses without reason, so I ask, did anyone reading this thread had fuses blown for no apparent reason?
Big Col
626
89
North Ayrshire
I'll go back and double check. It was updating every second or so i think. It wasn't a constant value. Yes, the car was stationary, at idle.
Thanks for your input anyway.
I'll just need to keep a torch and a supply of fuses in the car. Assuming it doesn't die again I'll just need to give it a scan every weekend or so to see if anything re-appears.
dm222
1,488
49
If it dies again then there is a problem somewhere you should check, I don't know how frequent are fuse break without a reason but it happens. It's very important to use a similar fuse.
Big Col
626
89
North Ayrshire
So I did about 25 miles last night with no issues. Gave it a vcds scan after that and all was clear.
Managed about 4 miles this morning and it blew again. Replaced the fuse and drove home.
I think all I can do is check the battery connections and the earths when I've got time over the weekend. After that I'll need to find a good auto electrician.
