Hi,
for RESET, you can try FACTORY RESET=RESET LIGHTS SETTINGS in the car MENU.
default % level for the DRL:
if you have LED DRL original value=127, if normal bulb than 100.
Rob
Thanks I think I've got it working now but that's good to know if it starts acting weird - The problem was the dimming direction in the instructions translated as "zoom" which isn't an option. It needs to be "minimise".
It seems like the values from all the active groups are compared (light on + indicators on etc), it can ether take the highest light value or the lowest. If you want it to dim when indicating it needs to take the lower of the values.
So have I got this right tiredness recognition can be enabled if car has tech pack but rear seat belts monitor requires hardware and tech pack? I have tech pack a d would like to enable both these functions ;)
I have tech pack too and im interested in tiredness enabling.
Does high beam assistent works front camera only?
EDIT: Anyone tested exhaust flaps open via vcds?does it make any difference?
vag familia
Yeah I've got obdeleven. Done a few small jobs nothing really major - turned sound actuator down, refuel quantity, air con auto light. Not got round to doing 5 flash convenience indicator and auto fold mirror. I also fancy trying enabling safety pack features but info seems a bit vague
I am a bit confused about the different versions of VCDS cables.
If you buy the newest version, for instance 15.7, is it then backwards compatible with all the older versions?
Yes,i bought 15.7.1 and works like charm until feb 2016..no problems.
vag familia
Guys,did anyone coded front blinkers as drl?
I want led and blinkers as drl,but only in sport mode.
All others modes only led is on as drl!
EDIT: found one on youtube,looks good did anyone tested it?
vag familia
vag familia
Working like charm :rofl:
STG 09, 31347, Adaptation,
Left Side
(4)-Leuchte 0 BLK VL B36-Lichtfunktion A 0,Ambientelicht 4
(5)-Leuchte 0 BLK VL B36-Lichtfunktion B 0,Blinken links Hellphase
(6)-Leuchte 0 BLK VL B36-Dimmwert AB 0,127
(8)-Leuchte 0 BLK VL B36-Lichtfunktion C 0,Blinken links Dunkelphase
(9)-Leuchte 0 BLK VL B36-Lichtfunktion D 0,not active
(10)-Leuchte 0 BLK VL B36-Dimmwert CD 0,0
(11)-Leuchte 0 BLK VL B36-Dimming Direction CD 0,minimize
(12)-Leuchte 0 BLK VL B36-Lichtfunktion E 0 – Blinken rechts beide Phasen
(13)-Leuchte 0 BLK VL B36-Lichtfunktion F 0 – Blinken rechts beide Phasen
(14)-Leuchte 0 BLK VL B36-Dimmwert EF 0,0
(15)-Leuchte 0 BLK VL B36-Dimming Direction EF 0,minimize
(16)-Leuchte 0 BLK VL B36-Lichtfunktion G 0, Blinken links Hellphase
(17)-Leuchte 0 BLK VL B36-Lichtfunktion H 0, Blinken links Hellphase
(18)-Leuchte 0 BLK VL B36-Dimmwert GH 0,126
(19)-Leuchte 0 BLK VL B36-Dimming Direction GH 0,maximize
Right Side
(4)-Leuchte1BLK VRB20-Lichtfunktion A 0,Ambientelicht 4
(5)-Leuchte1BLK VRB20-Lichtfunktion B 0,Blinken links Hellphase
(6)-Leuchte1BLK VRB20-Dimmwert AB 0,127
(8)-Leuchte1BLK VRB20-Lichtfunktion C 0,Blinken links Dunkelphase
(9)-Leuchte1BLK VRB20-Lichtfunktion D 0,not active
(10)-Leuchte1BLK VRB20-Dimmwert CD 0,0
(11)-Leuchte1BLK VRB20-Dimming Direction CD 0,minimize
(12)-Leuchte1BLK VRB20-Lichtfunktion E 0 – Blinken rechts beide Phasen
(13)-Leuchte1BLK VRB20-Lichtfunktion F 0 – Blinken rechts beide Phasen
(14)-Leuchte1BLK VRB20-Dimmwert EF 0,0
(15)-Leuchte1BLK VRB20-Dimming Direction EF 0,minimize
(16)-Leuchte1BLK VRB20-Lichtfunktion G 0, Blinken links Hellphase
(17)-Leuchte1BLK VRB20-Lichtfunktion H 0, Blinken links Hellphase
(18)-Leuchte1BLK VRB20-Dimmwert GH 0,126
(19)-Leuchte1BLK VRB20-Dimming Direction GH 0,maximize
I have recently bought a OBDeleven device as I simply didnt want to spend the money needed for a VCDS cable, and also bought a PRO license along with it.
So far I am very pleased with it and it is a lot easier when you just need a phone (android) and an internet connection. Most of the coding mentioned on forums in regards of VCDS and rosstech cable also seems possible to do with the dongle. I haven't tried out that much yet, but so far I have changed:
Teardrop wipe
Mirrors fold on lock (no need to long press)
Interior door leds always red
Comfort signal set to 4 (instead of 3)
Disable driver profile led to always off
I am actually thinking of trying out the coding of led drl as blinkers.
Kr.
/Heino
Teardrop
Coding
Module-09-> coding-7-> select from the drop down menu: Wischer-> byte01-> bit3 = ON
I havent tested it yet, but will do next time I get the car back from wife..
Folding and unfolding of Mirrors automatic or semiautomatic
1 - Electronic control module 09-. Code (31347)
2 - Adaptation
3 - Select - Control Access 2
4 - Sub - Funk modus spiegelanklppung
5 - Change value By command via remote control look key
If my previous coding doesn't work, I might try out this.
10 - Adaption
(17)-Windshield wiper-Traenenwischen Front Status - set to active
traenen = Tear - it might be easier to google examples if you search for the term Traenenwischen vcds, that was how I found it initially.
10 - Adaption
This one is working - tested it this morning.
obd eleven
i have tried three times without success to change mirror fold on lock and alarm chirp on lock, anyone any ideas?
when I check the app on my phone when connected to the obd it states that the alarm chirp is enabled-- starting to get aggravated
2014-cupra sc 280
I have the obd eleven app and tried as per previous post.
The mirror fold keeps saying 'something went wrong' please retry.
The lock unlock chirp is advising enabled.. Wierd
