Sorry to bump thread
Anyone got a picture of the sensor / plugin what needs cleaning and where abouts is it located.
I've got mine booked in with SEAT next Wednesday, if I could fix it myself would save me the £90 to scan the car
Cheers :)
I am currently dealing with this again also. Its behind the brake disc and is just screwed in and can be pulled out. Or take the disc off and look at the sensor of the hub and its condition
Do you have to take the brake disc off mate? I'm useless lol
If the rear then id say yes more convenient to do so. If fronts, then turn the wheel and go to the back of the hub. Easy half hour to an hour job. I will be doing my rear wheel again next week to either clean it or change
I'm sure the problem is at the front because the steering wheel fault clears sometimes when I wobble the steering wheel
Try and ask in the vagcom section on the forum or see if theres a smaller garage local to see if they can help but if you have the yellow steering wheel light on the dash, your issue maybe greater than just an abs sensor
Cheers bud I'll ask about
Sorry to drag this back up again guys did OP ever get this issue resolved as I have the exact same problems . Flashing handbrake light, power steering red light and extremely heavy , abs light , tc light . Just got it back from garage today and he's saying vag com won't scan the car.
