Unfortunately not. Only cars that can have full link enabled are my2016 onward with tech packCan that be done to a tech pack Leon that didn't come with full link version of the head unit?
Sent from my SM-G925F using Tapatalk
I am currently asking seat if i can retro fit to my 2014 car. I will let you know when they get back
Many thanks for contacting SEAT UK Customer Services regarding the potential of retrofitting Full Link to your vehicle.
I have discussed your query with our Parts Support Team; they have advised that it is not possible to retrofit Full Link to your vehicle.* The generation one radio system equipped to your vehicle is not compatible with Full Link which requires a generation two system.* Sadly this cannot be changed.
I understand this is not the news you wanted to hear and I apologise for any disappointment caused.
I wondered if all you'd need was:
- MIB2 Unit (Glovebox?)
- matching Screen (i.e removed from the same car as the MIB2)
- correct wiring loom between head unit and screen.
- USB/Aux Port and wiring to MIB unit.
Assuming you could get somebody to remove the component protection, and you had access to/competency with VCDS.
Can there really be more to it than than? I assume this will cost a few Pesos?
Silly question......
How will i know if i have a MIB1 or MIB2. Is it just a case of measuring the screen....
Car is a late 2014 Leon fr Tech
Your car will have the same as mine = MIB Generation 1. Easiest way to check: Pop out your Navigation SD Card from the MIB Unit. If the part number on SD Card starts:
5F0... =MIB Generation 1 system
6P0... = MIB2 Generation 2 system
What I don't know yet is if screens used with MIB1 units are compatible with MIB2. Anybody know this?
it is possible to retrofit it quite easily but to actually get it to work is hard. its requires software hacks and actually requires the processor to be sent to spain.
Looked into it myself and it was going to cost ££££
What you need is a MIB2 infortainment system unit, 6,5" or 8" screen and new USB/Aux port if you already have a 5,8" MIB infortainment system. You need to modify the screen connector HSD plug in the cars wiring harness by cutting few tabs. This can be done with a knife.
Some new wiring is also needed for the new USB/Aux connector.
If you buy a used MIB2 infortainment system unit you need to have the component protection removed by SEAT or send the unit to eastern europe to some hacker who has access to ODIS. Component protection can not be removed with VCDS.
In the link below you'll find some information about fitting the MIB2 unit and screen. Use Google Translate to change the text from Spanish to English.
www.clubseatleon.net/viewtopic.php?f=9&t=116935
Translated into English LINK
MIB2 Infortainment System Unit
5QA035824 without gps
5QA035834 without gps
5QA035846 with GPS
5QA035858 with GPS and DAB
Infortainment Screen 6.5 "
5F0919604A
Infortainment Screen 8 "
5F0919606
USB/Aux port
5G003522E
The 5,8" screens used with MIB1 units are not compatible with MIB2 units. They have different resolution. Also the connector to the 5.8" (MIB1) screen needs to be modified when upgrading to a MIB2 unit and 6,5" or 8" screen.
I've managed to purchase a few parts highlighted above. I will let you know when they arrive, how I go about removing Component Protection and what is required for installation and coding. Wish me luck!!
