The Wait is Over
ukoldschool
382
55
until you want to reverse with the door open (to avoid a bollard etc) and then it wont let you... or when it locks solid on on the drive for no apparent reason and wont let you go anywhere (happened on my wifes Mark 7 golf)
they are terrible, the worst bit Is people get used to them, then when they get into a car without they forget to put the handbrake on
Biker
1,593
12
Northumberland
Visit site
The Leon will let you reverse with the door open, just deselect auto handbrake and release the brake manually.
I wanted to hate the electric brake when I got the car, but can't. It just works and does what it is supposed to. If it ever fails to release, then I may change my mind.....lol
kazand
Is powered by Medtronics
Jun 6, 2010
4,138
73
Brum
The one in my previous 62 Passat was hopeless. Would come on when you didn't want it to and vice versa. Current 16 plate works a lot better , although I still find myself leaving it in gear... Just in case... :D
R4CK5
609
85
I have had no issues with the electric handbrake and I too was a sceptic to begin with. As said you can reverse with the door open, just requires releasing manually as you would with a standard brake.
I do tend to leave it in gear on inclines but this is something that should be done imo anyway as any handbrake can fail.
Biker
1,593
12
Northumberland
Visit site
Nice car :)
Give it a thousand or so miles and hopefully, you'll be creak free. Mine has developed a louder door creak than my 280 SC had, although I agree on the improvement in quality generally.
Scott
I will be gutted Scott if it does develop a door creak. I was one of the lucky 280 owners who never encountered that problem, fingers crossed.....lol
KXL
KXL
Dec 15, 2016
1,581
197
London, UK
E-brake used like mechnical handbrake?
Without the obvious answer of 'with skill,' any ideas how does this work if you have parallel parked up an incline and you need to reverse your way backways up (and out of a parking space) in a manual from parking? As far as I know, hill hold doesn't work if you roll forward trying to reverse up an incline.
I'm guessing the e-handbrake is fully on or fully release, and you cannot do an a la old school handbrake style, vary the level of handbrake hold you require to move the car without bashing into the car ahead?
Eg...on a steep incline, on a manual, you pull the old school handbrake to the required position (doesn't need to be max), clutch and gas, and as you are just about to pull away without rolling back, you drop the handbrake. Can you do the same with the e-brake?
My current and last Seat had mechinical handbrake, and my future car may have an E-brake, so just wondering.
R4CK5
609
85
I believe that the handbrake will automatically disengage once the required amount of force is applied when pulling away I.e. it will never drag the back wheels like you coukd effectively do with a manual brake. I could be wrong though. They're about the only situations I tend to miss a manual brake
Julio
35
Manchester
Lovely motor, in the best colour too.
Much prefer the aesthetics of an electronic handbrake, a nicer clean centre console. I think a manual one stands out like a sore thumb on modern cars now...don't forget we used to have chokes sticking out dashboards once upon a time! I've had a Passat CC which was slightly cumbersome with it's e-handbrake, as the switch was by the headlight control, but otherwise worked fine.
