Low BHP on Liquid Gauge.
Sparkie
Angling Adict.
Sep 25, 2009
2,554
780
Middlesex
Hi
So I bought a liquid gauge for my LCR recently. Good piece of kit all round.
I've not done dyno runs yet but I've checked boost and BHP.
Boost as I've found out is ok. Up to 14 psi.
On the BHP side of things it's pretty low.
Seems to top out at 221 :cry:
What would be the most likely reasons for this.
Dirty MAF?
Or is it the fact that having added aTIP, cone filter and heat shield along with a turbo back exhaust, the air flow has changed so much it now needs retuning to take these elements into account?
I was hoping for a gain on standard. Not a loss. So pretty deflated at present.
I know the turbo is not in the best condition, with play in the back and knocked blades on the front.
It still boosts ok but could this be part of the equation?
Any help would be golden. Cheers.
Sparkie
Angling Adict.
Sep 25, 2009
2,554
780
Middlesex
How does that gauge wire in? Is it accurate?
Apparently they are very good bit of kit. Quite a few people that used to frequent here have them.
It plugs strait into the OBD port.
It reads temp sensors, boost, torque, does digital gauges or graphs. does 0-60 and 0-100 times. Timing correction, code reading and clearing, throttle body resets. Probably even more than that. Fits into the air vent on right side of steering wheel.
I haven't fitted mine yet.
Sent from my iPad using Tapatalk Pro
Andrewwright
Turbo lover
Aug 16, 2016
1,567
224
Peterborough
Bit like the torque app but with more things.
Throttle body reset sound cool.
But there not going to be 100% Spot on.
The app has a delay but not sure what's the delay time is with you're plug-in which is what is is. But saying that I guess vag-com may have a delay..I've not used it yet but have download the free version to see what its like to use...need a cable first.
Sparkie
Angling Adict.
Sep 25, 2009
2,554
780
Middlesex
Doesn't look as slick as that. Nice.
Andrewwright
Turbo lover
Aug 16, 2016
1,567
224
Peterborough
I have a 6" screen on my phone or 7" tablet that connects to it with a Bluetooth adapter. You have an android phone? There is a free version for you to try and can pick from many different looks and many different plug-in apps for it.
Sparkie
Angling Adict.
Sep 25, 2009
2,554
780
Middlesex
Nope sadly apple.
Sparkie
Angling Adict.
Sep 25, 2009
2,554
780
Middlesex
There are some apps for the icrap but cost is just silly, bit like there phone's.
As you can tell..I don't like apple
All I've ever known. I was thrown in the deep end with apple computers when I went to work for s graphics company. I've never used a pc
Started using their phones and rest is history.
Sparkie
Angling Adict.
Sep 25, 2009
2,554
780
Middlesex
So do you recon once the car is mapped it will have gains that reflect what's been added.
Do you think custom mapping would be worth it?
mty12345
4,115
681
bristol
Your only 4hp away from what it should have been 13 years ago! As andrew says, it's just a rough calculation from the data, so i wouldn't say anything is wrong.
ibizacupra
Jack-RIP my little Friend
Jul 25, 2001
31,333
19
glos.uk
liquigauge is only calculating expected bhp not measuring it... based on calculated torque and airflow.
