Retrofit Auto Lights/Wipers on 2017 MY18 Leon FR
Darren_NI
22
Northern Ireland
Hello everyone, i was inspired by another thread on this topic on here, however this was for the pre-facelift model 13-16 year. seatcupra.net/forums/showthread.php?p=4714012
I have ordered a new model (MY18 i think) Leon FR Titanium Technology, these were pre-specced cars so unfortunately there was no way to alter/add options to it. Hence why I'm here :D
On the thread i linked above, a few users with the new model Leon's like mine have tried to do this but cannot find the options in VCDS to do it. So i am asking for help to anyone who knows how to do this on the new model Leons. Or could anyone confirm if the part numbers in the previous thread will work for Light sensor and Light switch.
I have full access to a Vag-Com, just want to know if i can defiantly order the parts from the previous thread,as they still look the same from the previous model.
They were:
-RLHS Sensor: 5Q0955547A
-Auto Light switch: 5G0941431AF
Any help much appreciated. Auto Lights is an invaluable option for me personally :p
Thanks.
iby104
76
10
Im also stuck on this, i think vcds settinvs are different from pre-facelift
Sent from my SM-G930F using Tapatalk
Joee
38
Im in the same boat.
I've done the physical install and can confirm both part numbers are correct. The sensor is working as I now have auto wipers (without any coding) and the light switch works as should other than auto which gives "vehicle lighting fault" message.
Tried coding on obdeleven and VCDS but with no success. After following the instructions on the other thread the sensor doesn't show up in the drop down menu. When on the long coding helper it doesn't give any description for what each byte is. I'm lead to believe the newer VCDS cable is required to get the long coding helper to work.
Darren_NI
22
Northern Ireland
Good to know the part numbers are same, thanks for that. Just a matter of coding the auto lights now :cry:
Joee
38
Yip easier said than done
I'm planning on buying the new cable at some point in the next few months hopefully. If/when I do I will keep you posted on if I get it working. Would/should work with the older cable if only the long coding helper worked!
Darren_NI
22
Northern Ireland
Do you know where i can buy the new cable and how much? My brother has the full unlimited VCDS he hasnt had it that long, wonder if it's possible that it already is the new one...
Joee
38
I believe the new one is the "HEX-V2"
They come in 3-VIN Limited, 10-VIN limited and UNLIMITED VIN so your brothers one might well be the new one. You would need to check the model/version of your brothers cable to know for sure
Darren_NI
22
Northern Ireland
I'll check with him to see, hopefully it is the newer one! Do you know if the long coding helper works on the newer cables?
Joee
38
I don't know for definite that it does work on the newer cable but I know for definite that it doesn't work with the older cable so this is my only hope ATM lol
Fingers crossed!
Darren_NI
22
Northern Ireland
Fingers crossed!
Once i get my car, i'll try his cable (if it is the newer one) and report back my findings, maybe a how-to guide as well if i manage to get it done.
Joee
38
Nice one mate. Same here, I'll post here if I get any further forward
simaservis1108
35
No,and they will not get anywhere.
New facelift BCM doesn't have coding anymore,only parametrization.
If you scan facelift BCM it will show coding as zeroes only.
For example:
Address 09: Cent. Elect. (J519) Labels:| 5Q0-937-08X-V2.clb
Part No SW: 5Q0 937 084 CG HW: 5Q0 937 084 CG
Component: BCM MQBAB H H34 0236
Serial number: 02001635605160
Coding: 000000000000000000000000000000000000000000000000000000000000
Shop #: WSC 00049 770 00128
ASAM Dataset: EV_BCMMQB 017001
ROD: EV_BCMBOSCH_017_SE37.rod
VCID: 7F580962C770E3EF220-802A
Control Unit For Wiper Motor:
Subsystem 1 - Part No SW: 5F1 955 119 A HW: 5F1 955 119 Labels: 5QX-955-119-V1.CLB
Component: WWS370 161113 041 0574
Serial number: 161201121321
Coding: 0BC5FD
Rain Light Recognition Sensor:
Subsystem 2 - Part No SW: 5Q0 955 547 B HW: 5Q0 955 547 B Labels: 5Q0-955-547.CLB
Component: RLHS 042 0105
Serial number: S7Y16M12D05H23M11S20
Coding: 00095D
Sun Roof:
Subsystem 3 - Part No SW: 6R0 959 591 D HW: 6R0 959 591 D
Component: J245 PS72.403 H03 0004
Serial number: 0000FST001CSGN800000
Coding: 180102
VCDS is pretty much useless as it is right now.
iby104
76
10
For example:
Coding: 0BC5FD
Coding: 00095D
Sun Roof:
Coding: 180102
Are you saying on the facelift model, theres no way of getting autolights and auto wipers unless it was from factory? I really want autolights on my leon fr facelift
simaservis1108
35
No,it is possible,I switched to facelift BCM and facelift Gateway because of retrofit of facelift headlights.
I am only saying VCDS is useless here.
It can be parametrized with other tools e.g. VCP,but you need a lot of experience not to brick the module.
