Status
Not open for further replies.
One last try on the OBD11 Forum I am able to build and index to link into book marks within a thread using BB Code.
The code I use is (I have removed []
a target="_self" href="web_page_details#gotohere"]Introduction[/a for the index section
and the bookmark is
div)(div)(a name="gotohere")(/a)(/div)[/div
I have tried this using BB Code editor and it still shows (should be hidden), is it possible to add these in so that we can have better how to guides / builds.
and the bookmark is
You've lost me a bit, sorry (might be the heat!)
Scott
No problem just me not being clear and simple.
if you look at this page http://forum.obdeleven.com/thread/764/coding-adaptations you will see the first post is just a index, if you click on each of the links it will take you to various bookmarks in the next post's
What you cant see in normal view is coding like [a target="_self" href="web_page_details#[B]gotohere[/B]"]Introduction[/a for the index section] in BBCode. The first part of the code tells you to jump to a bookmark called gotohere but you cant see any of that, the only bit you the user sees is Introduction.
Then further down the code [div)(div)(a name="gotohere")(/a)(/div)[/div] again this is done in BBCode and when you finish it you cant see it in normal view only in BBCode view.
I have tried doing this on this forum in the BBCode editor and it does not work, I presume this is because these codes are not supported here.
So what I am after is these codes to be supported or some other way I can build an index and associated bookmarks (otherwise i have to create a post for each section and that just does not give me what I am after.
Hope that makes sence if not we can chat about this on saturday (very quickly)
yes indeed, this is what happens with England win at football.
Had this a couple times today, security error. Working now but don't know if it's just me or if it needs looked at
So far not seen that issue on my (updated MAC) laptop, Pew was it via Mobile or normal computer connection.
Reactions: Syphon
Hi - we've now got a BB code editor installed. If you can let me know the codes you want listed out I'll try and get it sorted. PM me if easier.
Cheers,
Scott
Perfect i am doing some work on the house this week but will get it to you as soon as I can.
Reactions: Syphon
I am going to have to start a poll, what radio stations do you have on your first screen.
I see a lot of us have Radio 2 first :)
can you enable the bottom breadcrumb, i hate scrolling back to the top to go back to the forum i was in, that's far to much effort
Just to confirm you're after this sort of link at the bottom of each page for easier navigation?
We do have a take to the top or bottom nav button if that helps?
Reactions: Walone
Status
