Yes but we love them when they work as they should.
Agreed. These cars are getting old now, so you have to expect a few issues here and there. .....You don't shoot your nan just because she pisses herself every now and then.
Sad days. I just sold mine![]()
Well done does this mean you are no longer a Specialist LCR swimming pool constructor
scuttle panel absolutely does not clip back into the channel and is bowed out across most of its length therefore probably needs replacing
The pollen filter "lid" is cable tied to the scuttle panel as the mounting points are broken.
aaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaannnnnnnd the mofo is still leaking - badly. At my wits end so its decision time :-(
Sure it’s not a build up of standing water behind the dash that hasn’t totally been absorbed back into the air.
Which will produce steamed up front screen still??
No this is like a litre of water sitting in the floor pan - I'm convinced that because the scuttle panel doesn't fit properly it allows more water than it should between it and the windscreen which in turn is filling up that tray underneath.
Badger5 Custom Map + TIP,
3” Sustem, FMIC, Bosh 550’s,
BC Coilovers, ARB’s +loads more.
