Door Seals ?
Sparkie
Angling Adict.
Sep 25, 2009
2,541
779
Middlesex
Mine seems to have misted up on the front screen again this morning.
Aaaaarrrrrr!
Hope it’s the opposite side to pollen filter under scuttle panel that’s clogged up. Fingers crossed. Bloody cars!!
Badger5 Custom Map + TIP,
3” Sustem, FMIC, Bosh 550’s,
BC Coilovers, ARB’s +loads more.
masterfrodo
267
8
I got something less powerful, and less economical - makes perfect sense, not!
Mid life crisis time hit, and I felt the need for a two seater convertible, so have bought an MX5 Sport lol. It does handle well, but am having to get used to being without a turbo and oodles of torque - the MX5 needs to be revved to get the performance. It does sound nice though. I'll probably get over it in a year and come back to something more sensible
Deleted member 103408
Well done does this mean you are no longer a Specialist LCR swimming pool constructor
Gokiwi64
Geriatric Member
Apr 26, 2014
1,379
722
Hockley, Essex
So in no order are all the leaks
Nearside passengers door
Offside drivers door
pollen filter - scuttle
electrical connector box - scuttle
bonnet cable grommet - scuttle
Things to note, scuttle panel absolutely does not clip back into the channel and is bowed out across most of its length therefore probably needs replacing
The pollen filter "lid" is cable tied to the scuttle panel as the mounting points are broken.
iammooks
1,744
1,133
I took all this apart about three years ago to flush out the windscreen washer hoses and haven't had any issues with the ill-fitting panel. One of the two pins fell out when I put it back together, and the other one was already pretty deformed. Even with this there's been no water ingress, so with any luck you should be ok.
Sparkie
Angling Adict.
Sep 25, 2009
2,541
779
Middlesex
aaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaannnnnnnd the mofo is still leaking - badly. At my wits end so its decision time :-(
Sure it’s not a build up of standing water behind the dash that hasn’t totally been absorbed back into the air.
Which will produce steamed up front screen still??
Gokiwi64
Geriatric Member
Apr 26, 2014
1,379
722
Hockley, Essex
No this is like a litre of water sitting in the floor pan - I'm convinced that because the scuttle panel doesn't fit properly it allows more water than it should between it and the windscreen which in turn is filling up that tray underneath.
I am so sorry this is not sorted, can you not put something (talk powder or dye or water color etc) in the area and then soak the car to see if that is problem.
