Damn it
I must say that Ibiza probably has the worst designed dashboard center part ever... atleast when it comes to installing non OEM double din size head unit.
Like someone said before, the dashboard center trim piece (around head unit, storage compartment and climatronic panel) needs some cutting before there is even enough clearance to fit a double din size unit in. The "guide" rails of the storage compartment need to be cutted away.
The second problem I noticed is the Climatronic front bezel, which seems to be a bit convex.
Otherwise the Pioneer facia would be a perfect fit, but because of this it looks plain silly.
Has anyone found a double din mounting kit for Ibiza which would have a facia with slightly thicker bottom end?
Maybe the easiest way is just to warm up the excisting facia and bend it a bit.
Atleast the cheapest it is
but the instructions should
