DIY hardwire dashcam installation
Speedbird
268
135
This is my Blackvue...stealthy...
Really like that! Would a NextBase hardwire kit power one of these? Or are you using the OBD2 power lead?
Maypack
Apr 20, 2014
3,175
2,331
Gods Country - West Cumbria
I’ve got an OBD power lead and the cam is left permanently in the car. The standard nextbase mount wouldn’t work.
From the outside it’s pretty hard to see too. Easier to see the sticky mount!!
zeffania
476
159
Same, had mine in a car for over 5 years now. Just forget about it. I have a mobius and they are small, no screen so quite discreet. I cannot see it without ducking down as the mirror hides it completely.
Speedbird
268
135
So I drove to work and back today, having fitted my dashcam last night. Very happy with the cam.
However, on both journeys, I had no DAB signal. It worked perfectly up until today, so it must be something to do with the dashcam install.
I have a non GPS cam, Nextbase 212, and used a Nextbase wiring kit. Any ideas??
kiddo
ST Cupra
May 30, 2015
1,151
99
Lancashire
Have you pulled the fuse for the dash cam to cut power to be sure its the dash cam causing loss of dab signal. Sure another person on here lost dab signal when using dash cam. I seem to remember they needed to swap power cable to stop interference with dab signal.
eltawater
Full and wholesome member
May 1, 2008
322
55
It's a common problem with dashcams. Some people have found that the electrical noise from the usb cable causes the interference with dab and gps signals.
Search ebay for ferrite clip on
Sent from my SM-J510F using Tapatalk
zeffania
476
159
You get one of those with the nextbase kits although I never used mine and have no issues
daniel_ley
97
35
Dudley
I've got mine hardwired in, and I've always left in on display.
A lot of my friends have them too and I don't know any of them who remove them when parked up... however my luck ran out last month when parked up in Manchester...! Left it for about 2 hours and came back to this!
Happened to another car on the same car park too, again the dashcam was stolen.
I blame myself for parking in what was a pretty dodgy looking car park with no CCTV or pedestrians passing by etc. All fixed now and I have a new dashcam, and I've not suddenly started removing it just because of what happened, I'll just be more conscious about where I'm parking, and remove it when necessary.
eltawater
May 1, 2008
322
55
Sorry to hear that, was it one with a screen?
I'm wondering whether there's a rising trend for expensive looking cams being stolen as they can be up to a couple of hundred pounds now.
R4CK5
609
85
I did consider mounting mine behind the mirror, and actually bought a stealth mount from ebay so it would be a smaller setup, but then decided if I want to take the camera off, the rear view mirror would be in the way.
Do people generally leave the cam in their car permanently?
Just been for a test drive and no rattling. Can you return the mount and exchange it for a new one?
Cheers for reply, way past the point of claiming a new mount, it's been in a year and a half now. With the mount being semi flexible in the ball joint at the top I just tilt mine if I want to remove it, not that I ever do.
Speedbird
268
135
Well, having used my car quite a bit since my last post, the DAB reception problem seems to have disappeared. I have had perfect DAB signal ever since.
After daniel_ley's post, I have decided to relocate the camera though. It sits behind the rear view mirror now, which I prefer as the cam is virtually out of my view, and it is still removable. More importantly though, the mount sucker is now in the black dotted area of the windscreen, so is not visible from outside.
Blowski
Cupra 280 DSG
Mar 23, 2018
420
201
That's exactly where I have got mine positioned, means I have to move the camera angle when connecting to wifi etc but it's not a big problem. Can barely see it from the drivers seat
Blowski
Cupra 280 DSG
Mar 23, 2018
420
201
I worry about mine being nicked too. Since Nextbase updated their firmware the parking mode on my one has become a bit of a joke anyway so I might start taking it off when parked in more secluded areas.
Speedbird
268
135
After running 2 Nextbase dashcam's for 3 months now, just a word of caution from my experience about them.
I have a 212 fitted in my car, and was initially so impressed with it, I fitted one in my partners Focus too.
Hers was the first to start playing up. The camera would stay powered up, but the screen would freeze. It would lose between 2 and 7 minutes worth of footage between freezes. Tried a card reformat, still didn't work. Took it back to Halfords, got a replacement SD card, and still the same problem. Got the cam replaced, and so far so good.
However, after checking my own cam tonight, I have some video files on mine that are corrupt and don't play. I do the recommended 2 weekly SD card formats.
So Nextbase doesn't get my recommendation. Or if you do buy Nextbase, make sure you buy their SD card aswell, and keep the receipt!
zeffania
476
159
Have a nextbase I fitted to a work van and having to keep formatting rather than it overwriting automatically is a bit poor. My 5 year old mobius does that with no issues, but sadly the night mode is very grainy now. Might have to look at a replacement in the future. My mates Blackvue is great, but they're so expensive
Walone
1,720
508
Near Heathrow
I've had a Nextbase 512G camera for over 3 years now and not had any trouble (touch wood), excellent quality video and at night. I use Sandisk 32gb Ultra cards.
R4CK5
609
85
Gotta say, we run 5 Nextbase 312's with SanDisk cards and have experienced zero issues!
Another vote for the SanDisk cards, had one from the start, no issues whatsoever with either card or camera.
I have the 212 and mine automatically overwrites when the card is full. Formatting is just a recommendation I believe.
My only gripe would be that the g sensor is very sensitive and locks files all the time just because you've hit a bump in the road and speed and jolted too much. Other than that, camera has been faultless and you can turn g sensor off anyway. In the event of an accident there's no way it is going to keep running and running and overwrite your file after the event anyway.
