Carista App
Hag
399
193
Is there anyone(person or specialist)near Harrogate (N York’s) that can set things up for me using a Carissa type thing. I really am useless with this sort of stuff. Would ideally like to give the car to someone and ask them to do a list of things ie setting up some of the Carista features, fitting auto lights and wipers etc
ramborobert
174
51
Just had a play about with Carista so thought i'd share my thoughts.
1. disabled start stop (you cant override it with the button so its off permanently)
2. Enabled alarm chirp (It works but the volume is very low can it be turned up?)
3. Needle sweep (didn't work on the new digital Dash)
4. Soundakor (I turned it off at first and its amazing how much fake noise comes off it, and i can now hear the exhaust crackles much better however the whole exhaust and engine note is very quiet so i turned it back on at 50% mine was at 96% default at 50% i think its still too loud so gonna turn it down further. If i get a res delete in the summer i will be turning it off completely.
I haven't tried the direct throttle change yet and i think ill leave the xds alone.
Deleted member 103408
Alarm chip appears to be SEAT having changed something, older cars you got a good feedback sound, now ones you don't.
I believe the only thing that can be done (although not sure if Carista supports it) is you can use the Horn instead of the other method.
Stop start all you are doing is fooling the system into not working, it does not change how the button works so this is as per design although I have heard that the Cupra R does have a better setup.
Naylor92
273
52
Would you say it’d be worth getting one then ?
@Naylor92 You need to need to work out what you want from these tools and then see if they provide what you want
The communication dongle you need for Carista will also support lots of other apps (like Torque Pro etc) so its not dead money for the dongle.
Naylor92
273
52
I only want it to change a few little things. Just not sure exactly whether it can be done with Carista.
MGH74
47
Can you alter the DRL to 100 percent brightness with the Carista app? And can other things be altered, like the alternate indicator blinkers. Or is VCDS or OBDeleven needed?
Cheers.
Used mine for the first time today - Beta version. Both those options were available on Carista.
Although my DRL's were at 100% already, best bit was turning the soundakator off, it was at 97.6%!!!
In that case tell the guys here what you want to do and they will tell you if its possible, I dont use it (am OBD11 Guy) but for what you are after this is a better tool.
AlexOS
I tried the direct throttle response, but personally I felt no difference.
I have tried the soundaktor, but for me, it seemed to be either on or off, there was little or no change and then all of a sudden it was off. (although I prefer it off anyway)
I also tried the safety car indicators, but this didn't work, it just stopped the indicators on the body flashing, so only those on the boot lid worked. (i tried resetting the lights in the media system, but this didn't make any difference)
Craig Elliott
109
58
So how does this actually work?
Plug the part into the OBD.
Pair with phone.
Open app.
Click function you wish to activate.
Remove carista part from car.
Done? Or is it more complicated?
Naylor92
273
52
OBDeleven still not compatible with iPhone yet? Is there any other way you can use it other than having an adroid phone or tablet?
Maypack
Apr 20, 2014
3,175
2,328
Gods Country - West Cumbria
At the moment No. And when OBDeleven is available for iPhone it’s a different Dongle. I.e. if you already own an OBDeleven dongle you need to purchase a new one to use with an iPhone. Which is exactly what I’ll be doing.
Reactions: Naylor92
OBD Eleven are currently working on IOS Version scheduled for end Q1 2019 (Eg Ready in April I suspect).
In the mean time simple answer is no unless you are good with Windows or Mac laptops as i have seen you can create VM Partitions and run it there but it does not look easy.
Reactions: Naylor92
Naylor92
273
52
No I don’t have one. Just deciding on whether to get Carista or wait for the OBDeleven?
Naylor92
273
52
No haha!!
Carista it is then. You can always use the dongle for other stuff like Torque Pro
Reactions: Naylor92
scuj1
75
13
Edinburgh, Scotland
Can someone with a facelift tell me where the door LED menu should be on the infotainment system please? Was dicking about and can't find it anymore. Whenever I try to enable it on the app, the door LEDs go off with no option to turn back on.
