Coolant Leak? LCR
RichyH
290
7
Lincoln, UK
So after topping up my coolant twice in two weeks and the engine temp light just going off i think i have a leak. Front left on the car if your sat in the pilots seat is a suspect area, radiator maybe? Wacked the fans up high, filled the coolant up after turning her off for half an hour, and i got home without the temp going up past 90. Worth mentioning i did have a coolant hose replaced with an A3 hose not so long ago, slightly different hose but had no trouble for weeks before this issue so i don’t think it’s related. Any thoughts? TIA
Yellow fr
Sep 6, 2018
1,547
1,062
Sandbeds West Yorkshire
You just need to have a good look round all hoses and the radiator to see if you can see any water leaks with the engine running and not running
I had a radiator go on the join where the the plastic meet the core off the radiator bottom left
RichyH
290
7
Lincoln, UK
The thermostat housing's fail on these too, being plastic they get brittle over time and crack.
Just got a call from the garage with this exact diagnosis
So its just as simple as the engine not getting enough coolant? Seemed to be less worse when i cranked the fans up to full, albeit driving like a grandma
