Also got fit these ive been after for a while thanks to @Thai-wronghorse
Not updated in a while but ive got a full seal kit gor the front brembos of ebay for 20 quid. Brembo seals were 11quid each!! Just waiting for some decent weather to fit em.
Did you buy them in the end.
https://www.cbauto.co.uk/cookbots
These are the inserts to go in to the 45mm front bushes to reduce them to 30mm thus reducing movement. Then combine it with the adjustable powerflex bushes with the bigger insert even less. Solid mount subframe and you have a pretty rigid front end . Use upper and lower strut braces too
Reactions: bigT's lcr
