How come they decided to do that? Purely just to stop people like us messing with the "hidden extras"?not every one just some major changes along with earlier removeing long coding from bcm module.
It's definitely in the other section for me, I've highlighted it in the screenshot. Have you updated the app itself to the beta version in the play store or used the test flight thing if you're on iOS?
It's for the button itself, I don't think theres a way to specify which colour you want the doors to be without using the individual mode unless you have the facelift model, which has way more colours to pick fromIn terms of the "Driving mode button always in red", is this refering to the button itself or the Ambient Lighting LED's (in the door card) being always red no matter which driving mode? As I am looking for that.
It's definately not thereIt's definitely in the other section for me, I've highlighted it in the screenshot. Have you updated the app itself to the beta version in the play store or used the test flight thing if you're on iOS?
That's a shame. Maybe if you can see what kind of LED/bulb is on the circuit board you could try swap the orange one for a red one if you fancy dabbling with a soldering iron. At least the cellophane is doing the trick for nowIt's definately not thereI've emailed Carisa with the question.... is it only applcable to pre facelift cars. In the meantime, I took the switch apart and put a piece of red cellophane (from a quality street wrapper) inside the push button. Seems to work OK
It requires long coding which carista doesn't have. You can do long coding in OBD11 or using an actual VCDS unit, or pay one of the many people offering to do VCDS tweaks on Facebook marketplace and Gumtree to do it for/with youI was wondering if anyone knows if it’s possible to enable the automatic lights and automatic wipers using Carista in the facelift Leon, once the sensor and light switch has been changed. Have read it is possible with obd11 but can’t seem to find anything on carista. TIA
MFD carbon fibre background is much nicer than the default one, there's a MIB theme to go with it too, you can switch between the themes in the green diagnostics menu you access by holding down the menu button on the MIB, so you can change between the 3 themes without using CaristaWell got myself added onto the BETA again and so many options to play with
Park pilot visual activated. Missed that for last few days since I got the car.
Coming home lights activated
MFD carbon fibre background.
Need to play with it more when I get time
Mine only has the 2 buttons for main menu and full link,MFD carbon fibre background is much nicer than the default one, there's a MIB theme to go with it too, you can switch between the themes in the green diagnostics menu you access by holding down the menu button on the MIB, so you can change between the 3 themes without using Carista
When i held the home screen one it just came up with menu for software info not background options. but im on full link screen most the time for Waze (When full link works)
need to find time to have a proper play with the options on the car
In the BETA version there is an option for Gauges to be lit when lights are off. Also needle to be lit when lights are off.Hi all,
Is it possible to have the back lighting in the dashboard/media unit on at all times via Carista? Very frustrating how it sometimes feels dark enough that they should be on... but it hasn't kicked in yet
I've got the carbon background on my instrument display but not the centre screen. Can anyone let me know which one it is?
