Flat battery so had to try bump it off in the rain half dark backwards down a built up street with loads of obsticals. Failed as it was completely dead but a kind bloke jump started me after id pushed it plus ourlass and 2 kids 200m to the next car park. I love my leon, i really do...:banghead::rolleyes:
Let me know if you need anything mate
Attended a track day
Refurbished the arms i bought and fit new front bush's
painted the showing edge on the spacers but couldnt fit them as id bought the wrong bolts
changed the serpentine belt
fixed my leaky tire and swapped the fronts for the rears then did the tracking.
Refit my scuttle tray as i think thats where the leak is coming from. Will find out tommorow. If i haven't fixed it, its onto rear light clusters, doors seals...
Replaced the boost gauge pipe (still purple :)) rather than rag it out and feed the pipe through blind again i cut the head of a screw and joined the two pipes together and caked em in fairy liquid and just pulled the new one through.
Tried to fix the nsf window regulator and made it worse so had to disconnect the switch from the door so our lass doesn't drop the glass into the door lol. Need to find a replacement.
Also adjusted the tracking again.
Full interior exterior clean. As im half way through my 2weeks off the rear seats had become a wasteland of half eaten nuggets and chips so had to be done :eek: plus gave the boot a thorough gutting out and clean.
Reactions: lightup
Received my new cut key blades so changed them out on both my flip keys, however, when I tested them they wouldn’t turn in the ignition. On closer look the new blades have been cut a wee bit narrower than the original:
Contacted the company and explained this, they apologised and will cut & send another couple of blades
Reactions: bigT's lcr
fitted front mount intercooler and cupra r front bumper just need to work out how the front fogs are held in as I cannot see how they attach also need to get the top centre grill as there was not one with the bumper I got
New thermostat to try and solve overheating and lack of flow. Still exactly the same, suspecting that whoever did the timing belt last either didn't replace the waterpump or replaced it with another plastic impellor one.
Put the smoke tester on her. No boost leaks!!
Pcv to catch can pipe was split tho. Replaced and still a minor leak.
Need to order a different T piece as the one i have has a stepped end and i need it to be flat to get it air tight. Would be something IVE fit lol :doh:
Reactions: Leon20vt4
Put winter wheels back on the car. No alloy cleaning for a few months!:thumbup:
Oh yeah... I bought a red car too...
It’s got the wrong badge! Ha ha!! :doh:
Does the Leon stay or go?? A decision harder than Brexit.
Let’s just hope it takes you as long to decide if to keep it or not takes as long as Brexit. That way you’ll have it for many years to come!!:roflmao:
Hope you can keep it mate. I have mine as a hobby car and use my Volvo daily.
If you can afford to keep it as a hobby car I would, you’ve had it for so long.
Sleepless nights to come! Lol
I’m under no pressure to sell it quick so will not be making silly decisions.
Reactions: Leon20vt4 and Nizza
