Dash cam
Geraint Thomas
204
33
Hi all, I am looking at buying a dash cam for my 2016 Leon FR. Are they fairly easy to hard wire in etc.
The Daily Meme
Insta: @thatredcupra
Jan 3, 2018
912
466
Cambridge
Hardest bit about hardwiring a Dashcam Inn is rotting the cabling. If you follow the guide shown above it’s fairly straightforward to write in.
I found the hardest bit with mine, (i have the rear facing camera as well) was getting 3 PHAT wires into the A-pillar trim.
Reactions: Maypack
williamxb
79
35
Oxfordshire
A-Pillar trim was definitely a right PITA when I did mine, and I only had one cable to get in there!
Dead easy to hardwire, fusebox is easy to get into if you go that route too.
Kirky
Copper Cupra Advocate
Apr 10, 2019
1,042
497
Really easy. I fitted a Garmin 66w with no previous experience. The cable fits nicely around the top of the windscreen down to the glovebox where the fusebox is. I used the internal light fuse connection for permanently on power and the cigarette lighter fuse for the ignition switched power. I picked these for their minimal impact if something goes wrong on those circuits.
I think it took me less than an hour to do the whole job and no part caused me complications. Garmin's power connector is nicely packaged in a single cable so no issues hiding the cable for me. Definitely worth doing as looks a lot lot smarter than using the cigarette lighter.
Don1961
212
118
I found the hardest bit was routing cable from rear camera to front one. I ended up taping one end to a long stick and pushing (carefully) between headlining and roof. I pulled rubber door seal down to make sure I didn't damage the side air bags. Other than that it was straight forward.
