Tyre pressure seems high
Cupat
68
On an 09 1.9 tdi at 39 front 36 back that's according to most web sites I use. I've also got a mk4 Golf same engine but it's 32 all round on the same size tyres ie 205/55/16. Why's the Leon more.
R3k1355
1,786
251
Yorkshire
Someone has overfilled the tyres by accident? Drop them to 32 all around and see how it feels.
Double check with another pressure gauge first, just to check the first one was accurate.
Cupat
68
I had them at that but every place online said it was supposed to be the higher pressure now feels to hard. So drop it down again, why would it say such a high pressure..
R3k1355
1,786
251
Yorkshire
No idea, the tyre pressures should be in the owners manual and I think might be on a sticker in the door jam as well?
Don't trust everything you read online (said by some randomer online)
Legojon
I only wanted a remap
5,284
2,714
In both my Leon's the front is about 4-5 psi higher at the front (I assume cause of the weight of the engine). But whenever I have tyres fitted they always do 32psi all round. I guess cause it's the most common pressure and they don't want to adjust the equipment LOL.
Brimfull
1,385
418
Wrexham
Correct tyre pressure settings are on a sticker on the inside of the fuel flap.
Kenan
194
73
What pressure did you run on you Cupra?
Sent from my Redmi Note 7 using Tapatalk
DavieTDI
Brain dead
Aug 3, 2013
329
23
kilmarnock Scotland
Tyre pressure will always be the same even if you go from 16 to 18 inch tyres. Online tells me it's higher than what the sticker on the car tells me. I went from 16s at 34 front 32 back to 18s at 34 front 32 back all cold pressure.
Sent from my SNE-LX1 using Tapatalk
