Manual Rev Limiter
heliliam
99
This may be a stupid question but I am not too up on car engines.
I have a cupra 290 in manual and was having some fun today, anyway I messed the gear changes up and went into 3rd by mistake instead of 5th, and as I lifted the clutch I felt the car slow and saw the RPM's go into the red around 7800, just worried it may have damaged it or am I thinking too much into it ?
Legojon
I only wanted a remap
5,316
2,748
I wouldn't recommend doing it too often... if you'd dropped it in 1st would have been a disaster. But going into the red won't damage the engine (especially not just once). And 7800 isn't really that high when I get annoyed.
Wilkesy
255
29
I once put my old Ibiza fr into first instead of third, that was a big wake up call for me to stop driving **** lol
Jan 27, 2020
The chap I did my apprenticeship with worked with Honda back in the day and used to test the first gen of vtecs before release. They didn't have rev limiters on the tests and found very quickly they needed them in as the track drivers often blow them up around 12,000. The problem was they had to custom fit the engines in so after a lot of work, 5 minutes off fun on a track became very depressing. Every engines different but the red line should be the max before real damage kicks in.
SRGTD
2,744
1,602
Has happened a few times to forum members on golfmk7.com where the majority of members are from USA/Canada and a manual gearbox is still a bit of a novelty to some.
It’s known as the ‘money shift’ - for good reason - as the consequences can be very expensive is some instances if the driver doesn’t realise in time what they’ve done!
BigJase88
Jase
Apr 20, 2008
3,765
1,074
Oh my god its a stick shift :wtf::joystick:
BigJase88
Jase
Apr 20, 2008
3,765
1,074
It's actually very hard to do, if you are on the redline in 4th and accidentally go to put it into 3rd it is about impossible to do, if you are mid rev range in 4th and do the same it is possible, so more likely to make a mistake like this when pootling about not when at WOT
Rockbox
169
56
A while ago a mate of mine had one of the first lotus Elise he missed 5th and hit 3rd by mistake locked the rear wheels and went backwards through a fence lots of broken plastic and fibreglass but the engine was fine.
motty225
Polestar 2
Sep 11, 2008
953
219
Ashby De-La Zouch
Yes but if it happens at mid rpm in 4th it wouldn't cause an over rev, redline in 4th into 3rd would almost certainly cause an over rev
Dr.Dash
342
73
Midlands
With a 6500 rpm redline (?) then 7800 rpm is a significant over rev. Porsche use a 6 point grading system and that would be a 4 or 5, and classed as either engine damage possible or probable. Whilst it's not strictly valid using their system it is a starting point.
Just because the car is still running doesn't mean you've got away with it. Sending off an oil sample is cheap (c.£30) and easy these days and will give you an indication if there's any internal engine damage. Certainly worth doing if the car is still warrantied, as over revs will be logged and probably result in related warranty work being rejected.
Not trying to be a prophet of doom, but it is a significant over rev and ideally should be investigated a bit further rather than just hoping for the best.
Brimfull
1,385
418
Wrexham
"Stay in the black and out of the red, you dont get anything for two in the bed"
Jim Bowen 1989
Reactions: Dr.Dash
The Daily Meme
Insta: @thatredcupra
Jan 3, 2018
912
467
Cambridge
I was a little confused by @BigJase88's comment but i think what he meant was, being on redline in 4th, it is "impossible" to put the car into 3rd since the ratio for the gears to sync is too high. Unless you start double clutching, it would be difficult to change in to 3rd from a redline 4th. Most modern cars have syncromesh gears across all but the reverse gear.
BigJase88
Jase
Apr 20, 2008
3,765
1,074
Yes thats what i meant, at the redline in 4th would be almost impossible to get into 3rd unless like you say double clutch
Legojon
5,316
2,748
The redzone may go up to 8k rpm but the car won’t hit 8k the rev limiter will come in before then, probably just into the red zone
My dyno chart starts to drop off at 6900-7200. I don't recall it being able to go that high before the map though.
BigJase88
Jase
Apr 20, 2008
3,765
1,074
Maybe raised the limiter. Next time you are in the car bounce it off the limiter and then you will know, don’t worry it won’t break it thats why there is a limiter there
heliliam
99
I don't like to red line cars so when I went to shift up It was not near the red line, suppose that's a good thing lol, drove it today and it seems fine was just worried that's all.
BigJase88
Jase
Apr 20, 2008
3,765
1,074
Cannot beat a screaming vtec smacking off the limiter
Reactions: Brimfull
